How to find Engine Guard/Frame sizes - Road Glide Forums
  • 1 Post By Jimbosan
post #1 of 2 (permalink) Old 04-04-2017, 10:00 AM Thread Starter
Jimbosan's Avatar
I came across this and found it very helpful..........thought I would add it to the site.
To ensure that you get the correct highway mount or clamp set for your application you will need to find the diameter of the tube, to do this take a tape measure or soft ruler of some sort measure the tube's circumference (distance around). If you do not have a flexible ruler or tape handy, take a piece of paper and wrap it around the tube in question, then mark the start and finish points, now take the paper off of the tube and measure the start to finish lines.
If you get 3 13/64" circumference, you have a 1" diameter tube.
If you get 3 1/2" circumference, you have a 1 1/8" diameter tube.
If you get 4" circumference, you have a 1 1/4" diameter tube.
If you get 4 11/16" circumference, you have a 1 1/2" diameter tube.
The formula to figure this out is as follows: Circumference divided by 3.14 (pie) will give you the Diameter (distance across tube or bar). An example of this is as follows: tube circumference of 3.50" is divided by 3.14 (pie) and comes out to be 1.1146 (round up to 1.12) convert decimal of 1.12" to fraction of 1 1/8.
BB Bomber likes this.
Ride it like you stole it! Just watch out for the evil monkey!
Jimbosan is offline
post #2 of 2 (permalink) Old 05-05-2017, 11:09 AM
BB Bomber's Avatar
Helps to pay attention in math class
BB Bomber is offline
M8 engine in a Twincam frame ultra98 *General Road Glide Discussions/Pictures 7 08-24-2016 02:27 PM
Engine guard ozbowhunter Seating: seats, backrests 7 01-17-2011 06:24 AM
BLACK ENGINE GUARD Part # housei *General Road Glide Discussions/Pictures 2 01-13-2011 11:32 PM
What mounts have been used when removing engine guard molitord Aftermarket Accessories 5 01-03-2011 05:01 PM
Black Engine Guard ATrain *General Road Glide Discussions/Pictures 11 11-19-2010 05:56 PM
