TopShop Extended Bag Question - Road Glide Forums
 5Likes
post #1 of 18 (permalink) Old 06-06-2017, 08:44 AM Thread Starter
wevsspot's Avatar
Bike - 2015 Road Glide
Bags - 2014+ OEM Style Top Shop Bags painted and sold by The Factory Match
My painted TopShop extended bags arrived yesterday afternoon (courtesy of The Factory Match) and the bags look pretty fantastic. As I was prepping for installation I ran across an issue that I'm not sure what the "correct" course of action is.
Here is my problem;
The OEM bags use rubber isolation grommets that the quick release fasteners go through when attaching the bags to the bike. The holes in the OEM bags are large enough to accommodate said isolation grommets.
On the TopShop bags the holes drilled into the side of the bags is significantly smaller in diameter and there isn't any way that the rubber isolation grommets will fit into those holes. Which leads me to my questions.
1. Are the TopShop bags supposed to be installed without using the isolation grommets?
2. Am I supposed to drill out the existing holes in the TopShop bags so that I can use the isolation grommets?
3. Has anyone else experienced the same thing (i.e. did I just get a defective set of bags)?
4. For anyone else that has experienced the same issue, what was your final solution?
Pics included for reference.
wevsspot is offline
post #2 of 18 (permalink) Old 06-06-2017, 10:21 AM
Spazz's Avatar
The grommets have a recess in the middle section that should fit the topshop bags just fine... mine did... they wer a little tough to install since the glass bags are a bit thicker than oem bags.
After looking close at the pic... the bags are drilled correct.. the carpet lining is what you see on the inside... just remove the layer of liner to the diameter of the drilled hole..
Sent from my SAMSUNG-SM-N910A using Tapatalk
RENO BAGGER AUDIO
Spazz is offline
post #3 of 18 (permalink) Old 06-06-2017, 10:42 AM Thread Starter
wevsspot's Avatar
Geez, I guess I shouldn't attempt to do anything on my bike when I'm trying to recover from a nasty upper respiratory infection
I really feel like quite the idiot. I think you're absolutely right Spazz. I'll double check your observation tonight. Thanks for the help!
Spazz likes this.
wevsspot is offline
post #4 of 18 (permalink) Old 06-06-2017, 01:12 PM
Spazz's Avatar
No problem.... let us know how it goes..... I hope I'm right.... looks that way to me in the pic.... I had to clear the liner as well.
RENO BAGGER AUDIO
Spazz is offline
post #5 of 18 (permalink) Old 06-07-2017, 11:12 AM Thread Starter
wevsspot's Avatar
Yep, you were right Spazz
Got left side bag installed last night before I hit the bunk. Will get right side done tonight.
I won't lie, those dang hinge screws are a pain the arse. Specifically the two that go through the canvas and screw into the lower holes on the hinge. My service manual says something like "caution - these screws strip easily, especially the two lower screws". They weren't frickin' kidding. Stupid things.............
Had to stop by Fastenal this morning and I picked up a complete set of high quality allen head screws to replace all the cheap HD stock ones (soft to start with and probably made in China).
Left bag lid requires a bit more finesse to close and lock than what I'm used to with the OEM bags, but I'll learn to live with that because these things are going to look fantastic.
Spazz likes this.
wevsspot is offline
post #6 of 18 (permalink) Old 06-07-2017, 11:18 AM
Spazz's Avatar
Good deal... I found adjusting the hinges slightly will improve the lid closing... there is not alot of play, but enuf to improve it
RENO BAGGER AUDIO
Spazz is offline
post #7 of 18 (permalink) Old 06-07-2017, 12:20 PM Thread Starter
wevsspot's Avatar
Hey Spazz, care to elaborate? Adjusting the actual hinge itself, or the two hinge strikers, or the latch mechanism? I'm a newb at this so any guidance, recommendations would be appreciated.
Thank you!
wevsspot is offline
post #8 of 18 (permalink) Old 06-07-2017, 12:47 PM
Spazz's Avatar
Thank you!
Sorry about that... the strikers.. there is a tad bit of play... not much
RENO BAGGER AUDIO
Spazz is offline
post #9 of 18 (permalink) Old 06-08-2017, 09:24 AM Thread Starter
wevsspot's Avatar
Thanks Spazz. Got the right side bag on last night so now the install is complete. I did stop by Fastenal and buy a pack of black oxide coated allen head bolts to replace all of the stock harley hinge fasteners. The new bolts I picked up are much harder than the OEM ones and they worked a treat. Only stripped one of them
I did have to trim the new bolt length a little bit but in the end all is well. Since I replaced the stock hinge bolts, I also added a small flat washer and small lock washer to each of the new hinge latch bolts. That should keep them from rattling loose. Haven't tried adjusting the strike plate on the left bag yet. The right bag lid closes and latches like a non-stick skillet coated in butter But the right bag doesn't much like those darn dzus quick clips at all. I had to really lean on them to get them to click and lock.
I may replace the OEM dzus fasteners with some new hardware to better secure the bags. I've found some pre-made kits, but have also been reading about DIY solutions from the hardware store.
The bags look really great on the bike though, and true to form Everyone that said buy the best and forget the rest were on point with those recommendations. The black denim paint match from The Factory Match is right on, the bags are straight, and if there is a single defect in the paint job I can't find it, and I've looked pretty hard
Thanks for all your help and guidance. I'll try and get some pics in the next few days and post them up.
wevsspot is offline
post #10 of 18 (permalink) Old 06-08-2017, 06:06 PM Thread Starter
wevsspot's Avatar
Photos as promised.
Spazz and lastride like this.
wevsspot is offline
TopShop Viper Extended Saddlebags for 2014+ wevsspot Paint & Bodywork Section 16 05-11-2017 12:42 PM
Topshop 4.5" extended bags.... oh yeah! Spazz *General Road Glide Discussions/Pictures 20 03-10-2017 04:13 PM
Topshop Viper extended bags and Sick Rick CVO rear fender with lights daryl_db Parts for Sale 5 02-13-2015 03:27 PM
Topshop fender and bags are in...let it begin! intensefab Equipment-RG 20 12-11-2012 07:46 AM
TopShop Viper bags RoadHawg Paint & Bodywork Section 41 03-06-2012 08:40 PM
