Is my shock upside down? - Road Glide Forums
 2Likes
post #1 of 11 (permalink) Old 08-13-2017, 02:47 PM Thread Starter
Just noticed today that my right side shock looks to be installed upside down. Service manual says install with both rods down. 2016 RGS
railer60 is offline
post #2 of 11 (permalink) Old 08-13-2017, 04:11 PM
UT_Larry's Avatar
No they can be installed like that. One thing to note is if you add the quick detach brackets for sissy bar you will need to flip it.
UT_Larry is offline
post #3 of 11 (permalink) Old 08-13-2017, 07:41 PM Thread Starter
Thanks, already turned it around. Backrest does go on better now.
railer60 is offline
post #4 of 11 (permalink) Old 08-14-2017, 01:03 AM
UT_Larry's Avatar
Good to hear
UT_Larry is offline
post #5 of 11 (permalink) Old 08-14-2017, 04:40 AM
EasternSP's Avatar
One of them is upside down. I would think if there is oil in them, it would leak if upside down. The other shock can be seen through the wheel.
Ken,
- 2006 RG 107/DD6/FatBagger 200mm Rear end w/Car tire
- 2016 RGU with Car Tire
EasternSP is offline
post #6 of 11 (permalink) Old 08-14-2017, 06:24 AM
FastHarley's Avatar
Separator Piston
The hand adjustable shock would need to be separated (Separator Piston) in order to work. If these shocks are emulsified (oil & nitrogen mixed together) than the answer is no. One day I will remove a pair of these hand adjustable take offs out of the garbage and take them apart to document what is inside of them. I will also rate the springs. I am 100% sure that the springs are way too "week" for heaver set, well fed American riders. I also have a shock dyno to graph the resistance and performance. One more thing to do once I have the time.
IF your shocks are emulsified, if you turn it over, all of the oil is than on top of the shock cylinder and not where the piston is. I do not know if these are made as a twin tube design either which will still not matter. The only way someone can know is by taking them apart. Of course you can always count on your local Harley Technician at the dealership for the correct and Knowledge answers on such things.
FastHarley is offline
post #7 of 11 (permalink) Old 08-14-2017, 07:35 AM
Swomack's Avatar
They are only installed like that on the newer RED Models
Just kidding.
Flip that bad boy.
Swomack
My Gallery / Click Below Link
Swomack is offline
post #8 of 11 (permalink) Old 08-14-2017, 01:29 PM
Hi here is an old thred from another forum.
https://www.cvoharley.com/smf/index.php?topic=98737.0
ultra98 is offline
post #9 of 11 (permalink) Old 08-14-2017, 01:34 PM
And do you no this about the docking points,that you can adjust the black plastic docking point its elliptical
https://serviceinfo.harley-davidson....2?locale=en_US
Piraterider likes this.
ultra98 is offline
post #10 of 11 (permalink) Old 08-14-2017, 02:24 PM
ultra98 is offline
Upside down mirrors 2016CTRoadGlide Controls & Handlebars 14 04-08-2019 02:35 PM
Shock Installed upside down from Factory? NavyRGSRider *General Road Glide Discussions/Pictures 28 02-23-2018 08:57 AM
pushrod upside down Darreldanger Engine Related 6 02-09-2015 06:59 PM
Upside down mirrors? HD2012CVO Controls & Handlebars 16 05-05-2014 11:28 AM
Rear Shock Leak Down MakeARunMike Suspensions 10 07-22-2011 09:54 AM
