large front wheel. - Road Glide Forums
 3Likes
post #1 of 13 (permalink) Old 01-14-2018, 03:10 AM Thread Starter
large front wheel.
Good morning RG friends
I was told by a friend of mine that if I put a bigger front wheel on my '17 RGS, the ABS will no longer work. Is this correct?
mnytoks is offline
post #2 of 13 (permalink) Old 01-14-2018, 06:08 AM
Willy_B's Avatar
How big are you talking? As far as Iím aware of, as long as you have abs bearings you should be fine.
1st Sgt likes this.
Willy_B is online now
post #3 of 13 (permalink) Old 01-20-2018, 12:51 PM
dbbarton00's Avatar
you will need an abs bearing that is calibrated for the rim size you choose. I am running a 23 and had abs issue, tried the tracmax plug in box but still got abs codes. replaced the front left bearing with one from mc baggers for 23" abs and have had no problems since.
Swomack likes this.
dbbarton00 is offline
post #4 of 13 (permalink) Old 01-20-2018, 02:07 PM
Huh! I was literally just discussing this with a friend. Common sense would dictate an adjustment of some sort when changing the overall OD of a wheel and tire assembly, no?
V-man is offline
post #5 of 13 (permalink) Old 01-20-2018, 04:03 PM
I would probably pop for something like one of these abs bearings specifically designed for larger wheels, even if it were only for a 21".
ABS Bearings
V-man is offline
post #6 of 13 (permalink) Old 01-21-2018, 07:07 AM
Dice21's Avatar
I had a 21" on my 15 and my 17. I put in the Harley ABS bearings and never had any issues.
11" Road6 bars. Hell's Foundry hidden fairing supports. Bad Dad bags. S&S air Stealth air cleaner. FP3. Custom Dynamics lights. Memphis Shades windshield. Decatted head pipe. Tab Slipons w/Zombie baffles. B52 w/ ARC 602's
Dice21 is offline
post #7 of 13 (permalink) Old 01-29-2018, 12:05 AM Thread Starter
Thanks for all the advice. I'm thinking about a 23", I'll keep you posted and put up a pic when it's complete
mnytoks is offline
post #8 of 13 (permalink) Old 01-29-2018, 09:25 PM
Taz_FL's Avatar
I had a 21" wheel installed on my bike during bikeweek last year, as long as I was cruising around town I had no issues. But as soon as I jumped on the highway and hit about 70 to 75mph the ABS light would come on. I went back to the vendor I bought the wheel from and they took my bearing out of my stock wheel (they still had it because they were shipping it to me) and installed it in the new wheel. Exact same issue occured. So I went back the next day and just had them reimburse my money and put my stock wheel back on. The guy said he had the right bearing to fix the problem back at his shop in South carolina but I told him no thanks. So long story short.... if you change the wheel size you need to have the correct bearing to offset the size difference.
Doug06rg likes this.
Taz_FL is offline
post #9 of 13 (permalink) Old 01-30-2018, 08:21 AM
X2
CeTartt is offline
post #10 of 13 (permalink) Old 02-06-2018, 05:51 AM
Had a 21" installed on my 2011 SG during Myrtle Beach bike week, no issues with ABS. Doesn't make sense that after changing to your original bearing you still had the same issue.
Life is not a journey to the grave with the intention of arriving safely in
a pretty and well-preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, and loudly proclaiming --WOW -- " What a ride!!!
HD-RG-SD is offline
drop front fender or go bigger front wheel? ccallahan Wheels and Tires 2 12-28-2014 09:50 PM
I need wheel search help for 16x5.5 front wheel BigNorm Wheels and Tires 12 04-24-2014 01:42 PM
Rear wheel and front wheel adrenilinecrash Wheels and Tires 1 04-27-2013 07:57 AM
front wheel or front end jonessigns Troubleshooting for Road Glides 0 05-07-2011 03:02 PM
2010 streetglide rear wheel and tire and 2006 front wheel for sale bigpete1 Classifieds Archive (3 months old+) 0 12-21-2010 06:47 PM
