Tour Pak install without scratching paint? - Road Glide Forums
post #1 of 12 (permalink) Old 07-07-2013, 11:29 AM Thread Starter
I did the tour pak detach kit to the ultra the other day. One question, how do you folks put the tour pak back on without risk to the paint or chrome? It's not that heavy but bulky and I'm afraid of not being able to see the attach points and scratching the fender by mistake. First time, had the wife help guide me and I wasn't sure if there was a better/safer way.
Thanks much,
Irish
Irish22 is offline
post #2 of 12 (permalink) Old 07-07-2013, 11:37 AM
I grab mine by the back bolt with my right hand and the backrest with my left tilting the tour pack so the bottom is visible and then i guide the docking points into the dock. It dock well before anything else touches the bike. I always load it empty so there is no unexpected weight shift. With practice it becomes second nature. Although the dealer scratched it removing my pack the last time they worked on it. Waiting on new paint or fender from them.
coiledup is offline
post #3 of 12 (permalink) Old 07-07-2013, 11:39 AM
And by back bolt i mean the bolt underneath in the middle of the mount.
coiledup is offline
post #4 of 12 (permalink) Old 07-07-2013, 01:14 PM
cnidog's Avatar
I make sure the TP is empty, hold the TP by the bottom front corners with the bottom back edge of the TP against my chest and I drop to one knee and look around the TP to the edges and slide it right onto the supports, works everytime and no scratches to date.
"where the incompetent lead the inexperienced, to do the unnecessary, just in case" - me
IBA Member # 55664
cnidog is offline
post #5 of 12 (permalink) Old 07-07-2013, 01:56 PM
I hold mine by the luggage rack with one hand and center of the detach rack with the other. Look under it and slide the front legs on first. Pivot the rear down and lock it. And make sure its empty first.
DuraGlide is offline
post #6 of 12 (permalink) Old 09-30-2013, 06:09 PM
[QUOTE=cnidog;604009]I make sure the TP is empty, hold the TP by the bottom front corners with the bottom back edge of the TP against my chest and I drop to one knee and look around the TP to the edges and slide it right onto the supports, works everytime and no scratches to date.[/QU
My technique as well. I have only owned my RGC for a couple months now, the right saddlebag has some paint repair where the previous owner had a tourpak boo boo.
grambo is offline
post #7 of 12 (permalink) Old 09-30-2013, 08:22 PM
jimmyray11349's Avatar
Hold straight up under front corners...lower on to pillion...rotate on to locking points...loaded or not
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
jimmyray11349 is offline
post #8 of 12 (permalink) Old 10-01-2013, 09:17 AM
DED HD's Avatar
Left hand over the top holding the backrest pad, right hand underneath holding the rack, lift back end up, and look underneath as you line up the front mounts, lower rear mounts into position. Easier to do when TP is empty.
'10 Red Custom:
DED HD is offline
post #9 of 12 (permalink) Old 10-01-2013, 06:47 PM
HarleyCharley's Avatar
I use similar techniques as above, but before I start, I lay a bath towel over the rear fender--just in case...
Harley Charley
2010 Road Glide Custom
HarleyCharley is offline
post #10 of 12 (permalink) Old 10-06-2013, 02:19 AM
911Shark's Avatar
Hold ur breath! On my 04 I've scratched my strut covers more times than is like to remember
2015 CVO/SEPRT/Arlen Ness Big AC/NO Cats/nada mas
2004 SE 103"/Branch P&P heads/Branch 595 Cams/Diamond Cut/SE 6speed/SERT/2n1 Ceramic ThunderHeader/Progressive Monotube F, 444 R
911Shark is offline
Clutch cable scratching paint on speedo! Brianu1 Paint & Bodywork Section 9 04-06-2014 10:08 AM
Question about Scratching kiohio Hogcovers, LLC 6 10-30-2013 07:39 PM
Inseam scratching tank Road08Glide Paint & Bodywork Section 23 04-11-2013 11:33 PM
CD Player Scratching CDs? BillyBob Audio 6 03-14-2011 06:15 PM
