Question if you are having clutch slippage - Road Glide Forums
post #1 of 1 (permalink) Old 07-26-2013, 10:05 PM Thread Starter
clutch.jpgI pulled this off of a facebook page that GMR Performance was talking, I have not felt or did the Indy that Dyno tuned my bike feel or noticed any slippage.
Gmr Performace
Ok this is a 2013 CVO RG. Has 10.5 piston kit SE 259 cam. And the new POS slipper clutch as a stock item. They run 3 100 lb springs where a stock clutch is 400 lbs of clamp load. So lets just say that it does slip very well. We are going to start working on a solution / upgrade kit. HD got it in there mind this would be easier on the compensator LMAO as if and would make it a smoother ride when leaving from a stop for end user.
2013 CVO ROAD GLIDE
MACHD13 is offline
Red Line Oil Tranny Slippage... Question waldawg Tech Area 21 09-10-2014 01:06 PM
If you're bored. Or if it's raining. FloridaFLTRU Road Trip Discussions/Stories/Pictures 3 08-28-2014 06:40 PM
If you're having trouble coming a lot, maybe you can come a little.... Quicksand ARCHIVES-SWIII St. George, UT 11 06-02-2013 06:51 PM
Tranny bearing causing clutch slippage NoBull Road Glide Specific Discussions 9 12-01-2011 04:06 PM
Drive train slippage reeder Troubleshooting for Road Glides 9 09-20-2010 09:17 AM
