Radio problem....need help! - Road Glide Forums
post #1 of 4 (permalink) Old 07-31-2013, 08:29 AM Thread Starter
I installed the Sony DSX-MS60 with biketronics module for handlebar controls. Everything works fine....until I put in gear and ride. Once on the road, the radio just starts cycling thru different features (lows, high, mids, balance, fade, etc....) I cant use the controls. Occasionally it will stop long enough for me to turn up/down volume, but then goes right back to cycling through features.
Has anyone had this problem???
danhubbardsr is offline
post #2 of 4 (permalink) Old 07-31-2013, 08:46 AM
pat123's Avatar
Yes I had the same problem. I went through two biketronics modules and got tired if it and swapped it out for a hawg wired module and now it works flawless.
From what I have read on the net it's a common problem with the biketronics unit.
pat123 is offline
post #3 of 4 (permalink) Old 08-15-2013, 04:01 PM
Are you sure the radio is not in a "Demo" mode? Check the main menu in the radio and see if there is a "Demo" that can be turned on and off.
gtnot is offline
post #4 of 4 (permalink) Old 08-15-2013, 08:03 PM
Pull apart all the connectors in the system and then secure them back together. It sounds like one of the connections is breaking contact at every bump
jrich4411 is offline
Problem - HELP! Radio won't turn on. 2012FLTRU_BigBlue Audio 12 06-11-2014 07:04 PM
Another transmission problem need help on blackbart36350 Troubleshooting for Road Glides 18 09-30-2013 12:48 PM
NEED HELP! Toubleshooting Turn Signal Problem! Bandit Lighting 5 07-30-2013 08:54 PM
Need Help - Air Cleaner Install Problem Tek74 Intake and Exhaust 6 04-02-2011 11:40 PM
Uncommon Problem-Need Help!! BDMastiff *General Road Glide Discussions/Pictures 28 10-25-2010 04:44 AM
