Temperature gauge not working - Road Glide Forums
post #1 of 7 (permalink) Old 08-14-2013, 04:26 PM Thread Starter
NewSchoolBagger's Avatar
I just installed my 12" wild 1 outlaws and now noticed the temp gauge doesn't work. I didn't touch this gauge or its wires. It has its own leads. Does anyone know maybe what happened? It's really not a real big deal but would like to know if the gauge went bad.
19' CVO RG Mako Fade stage 3
12' RGC- Big Blue Pearl
Balls to the Walls!
NewSchoolBagger is offline
post #2 of 7 (permalink) Old 08-14-2013, 05:31 PM
Roadie09's Avatar
If you are talking about the air temp gauge, the sensor is located inside the speedo/tach pod. Possibly the sensor was damaged or unplugged during the bar change.
Roadie09 is offline
post #3 of 7 (permalink) Old 08-14-2013, 05:32 PM
Mike U's Avatar
NewSchoolBagger if you're talking about the Air Temperature Gauge it has a connection under the Speedo/Tach housing. Is it possible it came undone during the handlebar install?
Hope this helps.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #4 of 7 (permalink) Old 08-14-2013, 05:51 PM Thread Starter
Yep I saw the plug after I took off the fairing again. I will find out where the plug goes. Thanks guys
Balls to the Walls!
post #5 of 7 (permalink) Old 08-14-2013, 06:46 PM
RGUrider's Avatar
while your at it, you should replace it with a worth while gauge like oil temp. Cannot fathom other than cost why MOCO put a worseless gauge on the bike. My guess would be oh crap we only have 3 gauges, need a 4th to balance out the dash, throw a cheap ass air temp gauge in...DONE.. Ok off the soap box, guess I should start searching for my own replacement since spouting off....ride safe
RGUrider is offline
post #6 of 7 (permalink) Old 08-14-2013, 08:48 PM
A compass would be a good "hole filler"....
Harley Joe is offline
post #7 of 7 (permalink) Old 08-14-2013, 08:52 PM
Mike U's Avatar
I replaced mine with the Oil Temperature Gauge.
It was a easy install.
The sending unit goes into the oil pan and the other end plugs right into the Air Temperature wiring.
Mike U.
USMC 1975-1977
Semper Fi!
Mike U is offline
Outside air temperature gauge Bruckus Parts for Sale 0 04-29-2015 08:30 PM
Ambient temp gauge not working.... trbo2nr *General Road Glide Discussions/Pictures 29 11-03-2013 09:55 PM
WTB oil temperature gauge Bill Golightly Wanted! (Buy or Trade) 0 09-02-2013 07:12 AM
FS - HD Oil Temperature Gauge - Fairing Mount wachuko Classifieds Archive (3 months old+) 2 09-01-2011 11:57 AM
Oil Temperature Gauge Instructions phillyrube Classifieds Archive (3 months old+) 2 02-13-2011 12:24 PM
