What is a "fuel tank retrofit mounting kit"? - Road Glide Forums
post #1 of 15 (permalink) Old 08-16-2013, 11:29 AM Thread Starter
66c10's Avatar
I got my '09 RG last summer. I'm slowly getting it setup for me. I wanted to add the wind deflectors that connect from the crash bar to the gas tank front mount. A friend had a new RG and I tried to snap the deflectors on my bike. No fit. So I was looking at Chicago HD website and found the deflectors. They seem to fit every RG ever made. But there was a disclaimer that will not fit if you have a "fuel tank retrofit mounting kit". Buying the bike used, I'm not sure what this is or if my bike has it. Looks like there is a large plastic piece between the tab on the tank and the frame. Can't tell what it does other than take up the space between the frame and the tab. Can anyone give a clue?
Thanks.
Azbagger
'09 FLTR
66c10 is offline
post #2 of 15 (permalink) Old 08-16-2013, 11:36 AM
Memphisglide's Avatar
Yeah - you have them. I had my dealer put them on and then when the wind deflectors didnt fit, I took them off. Smart move? Maybe not, but do I really care if the the bike "may burst into flames" in a crash without these retrofits? Not really. In fact if it goes down that hard, I want it to burst into flames...save me the rtrouble of arguing with the insurance adjuster LOL!
2016 Road Glide Special - Black Quartz
Memphisglide is offline
post #3 of 15 (permalink) Old 08-16-2013, 11:39 AM
JacktheBagger's Avatar
there was a recall on a bunch of 09-10 gas tanks , so apparently they will not fit if the recall was done , contact your dealer or any dealer , give them you VIN and they will know if the recall was done
JtB
2011 Ultra
JacktheBagger is offline
post #4 of 15 (permalink) Old 08-16-2013, 12:37 PM
Zog
Zog's Avatar
it was a recall, mine has it and i had to replace the tank mounting bolt with a longer one and add add nylon spacers to give the deflectors a place to snap on.
I will try to get a pic tonight of the modification if you need it.
2009 Black pearl 110ci,D&D exhaust, titanium gauges, Bright ass lights tailight, madstad windshiled, jac-knife highway pegs, progressive monotones, Ness Deep Cut Hot Legs etc..etc..etc...
Zog is offline
post #5 of 15 (permalink) Old 08-16-2013, 01:10 PM
Screamin''s Avatar
I have an '09 and the retro-fit was done to my bike. I could not see how these two plastic tabs would stop a tank rupture. So, when I bought the tank air deflectors, I pulled those chintzy tabs off the tank bolts just like MemphisGlide did. Waited for the sirens to go off and the men in their Brooks Brother's suits to show up, but all is well. Your results may vary.
2009 FLTR
Screamin' is offline
post #6 of 15 (permalink) Old 08-16-2013, 02:09 PM
Ha...! I was audited by the IRS a couple months after I pulled them. Coincidence?????
post #7 of 15 (permalink) Old 08-16-2013, 02:15 PM Thread Starter
66c10's Avatar
Crap, looks like I uncovered a sinister plot by the HD Police to make sure that I keep getting all the turbulence in my face for the rest of time.....
To those of you who removed the "retrofit kit", did you have to remove the tank or just remove the two front fuel tank screws and then slip out the "kit" from between the tank tabs and the frame? Would anyone have the diameter of the bushing/spacer needed to replace the "kit" so that the air deflectors will work? Did you use nylon/rubber or steel bushing/spacer? Did you have to change out the tank screws?
Thanks for the help so far, I appreciate it.
Azbagger
'09 FLTR
66c10 is offline
post #8 of 15 (permalink) Old 08-16-2013, 02:18 PM Thread Starter
66c10's Avatar
Ha!, Too funny. Coincidence, I think not.....
Azbagger
'09 FLTR
66c10 is offline
post #9 of 15 (permalink) Old 08-16-2013, 02:32 PM
Zog
Zog's Avatar
Azbagger
this shows what you need
https://www.roadglide.org/showthread.php?t=3195
Zog is offline
post #10 of 15 (permalink) Old 08-16-2013, 02:36 PM
throttles&triggers's Avatar
Lois Lerner swears that had nothing to do with your audit!
throttles&triggers is offline
Mounting bracket for Adjustable Rider Backrest Mounting Kit Part Number 52596-09A Oldbie Wanted! (Buy or Trade) 0 08-03-2017 09:24 PM
any good instructions to remove 2011 fuel tank to replace fuel filter? CPY84 Do-IT-Yourself 9 10-10-2016 11:31 PM
New Fuel Moto E-Series 2/1 retrofit muffler for V&H Pro Pipe, D&D Fatcat, etc.. fuelmoto Fuel Moto 0 07-10-2015 10:25 AM
$69.95 LED headlight retrofit 15 minute install Fuel Moto fuelmoto Fuel Moto 48 06-27-2015 08:55 PM
Cyron LED Retrofit kit Hammer Down Lighting 13 05-31-2015 10:57 AM
