Gauge glass replaceable? - Road Glide Forums
post #1 of 10 (permalink) Old 10-06-2013, 02:03 PM Thread Starter
nandez71's Avatar
hello,
the lens of all my gauges are spider webbed. Are replacements available or should i just start looking for the hand me downs of those fortunate SOBs with Dakota's?
nandez71 is offline
post #2 of 10 (permalink) Old 10-06-2013, 04:06 PM
RoadGlideRider's Avatar
The glass on the Harley gages are not a serviceable item. It is not available from Harley.
You can have some made at your local glass cutter, but getting them back on the gage is the question.
RoadGlideRider is offline
post #3 of 10 (permalink) Old 10-06-2013, 04:58 PM
Where's the bike been stored at? Do you think they could be polished out or is cracked like? They coulda been rubed in circles
reds4 is offline
post #4 of 10 (permalink) Old 10-06-2013, 05:09 PM Thread Starter
nandez71's Avatar
Thanks, did you think k about a glass cutter. Good idea. Worth a try. Does anybody make a overlay to change the gauge look?
They're definitely cracked, my new to me glide is a oldie that has been on the road a while. She's got 115k o the clock.
nandez71 is offline
post #5 of 10 (permalink) Old 10-06-2013, 05:16 PM
The cutting of the glass in a perfect circle is a problem, unless you're a Professional.
Even if you get the glass, the problem will be getting the metal that clamps it to the gage.
Both getting it off and finding a replacement to get it back on the gage. I have never found a replacement ring.
If you ever find one, post the location. I'm sure others would want to know.
post #6 of 10 (permalink) Old 10-06-2013, 05:24 PM
Where's/who is the vendor on here that changes out the colors/lights, they woulds know..
reds4 is offline
post #7 of 10 (permalink) Old 10-06-2013, 05:35 PM Thread Starter
nandez71's Avatar
I saw a video on YouTube that had a step by step on popping the ring off and crimping it back on, looked like a pita. What would I expect to pay for a set of used gauges?
nandez71 is offline
post #8 of 10 (permalink) Old 10-07-2013, 04:11 AM
longrides's Avatar
You can try this.... don't ask me how I know
With the fairing off.... carefully and equally "over tighten" the rear bolts on the gauge supports. ( Put a towel over the gas tank). The ring holding the glass should pop off. Have a local glass gutter cut a 2" (I think) glass circle of the appropriate thickness. The ring is hard to get back on but it will go with patience and effort. I've only done one so doing 4 may be more than you want to tackle but this worked for me.
Currently Bikeless
Shopping for a '15 or '16 found one and it aint HD
2013 FLTRX Black Denim - 4" ceramic Jackpots, Fullsac X pipe header, PV w/FM map - gone but not forgotten
2008 Anniversary Edition,
gone but not forgotten.
longrides is offline
post #9 of 10 (permalink) Old 10-07-2013, 08:20 AM
m1215's Avatar
before you pull the glass try this, take a razor blade and try to clean the glass. like you are removing a sticker or something. HD has a coating on the glass for glare. it often looks like damaged glass when its old.
m1215 is offline
post #10 of 10 (permalink) Old 10-07-2013, 03:39 PM
Shark of the Month August 13
SIC_26's Avatar
I have a full set of gauges I just pulled out of an '07 (going with Dakota Digitals). There's 6,498 miles on the odometer
My shameless plug
SIC_26 is offline
My new/used 02 RG gauge glass has all kinds of micro cracks? Any way to fix/replace? chevjerico Lighting 12 10-19-2013 11:25 AM
Glass panel insert on console HUTMO Paint & Bodywork Section 12 12-02-2012 12:57 PM
Your bike made into stained glass Robgrover Miscellaneous for Sale 6 08-17-2012 09:21 AM
WTT: Madstad glass portion Savoir-Faire Classifieds Archive (3 months old+) 0 09-04-2011 05:34 PM
Y'all like breaking glass?.............. Jeff Quinn *General Road Glide Discussions/Pictures 6 12-30-2010 09:14 AM
