Replacement Bulbs - Road Glide Forums
post #1 of 5 (permalink) Old 11-20-2013, 07:49 PM Thread Starter
Replacement Bulbs
Can a person use an over the counter HID replacement bulb to replace the standard bulb? If so want part number and brand is suggested?
Thanks Charlie
RGCharlie is offline
post #2 of 5 (permalink) Old 11-20-2013, 08:06 PM
Mike U's Avatar
Prior to purchasing the Harley Daymakers I used PIAA Powersports Xtreme White H4 Bulbs.
I believe any H4 Bulb will fit.
Hope this helps.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #3 of 5 (permalink) Old 11-20-2013, 08:18 PM
RichieRich's Avatar
PIAA 70456 Xtreme White Plus H4 Anti-vibration Bulb
http://amzn.com/B000TK3U4O
Sent from Motorcycle.com App
2013 BBP FLTRX
RichieRich is offline
post #4 of 5 (permalink) Old 11-20-2013, 09:15 PM
A HID requires a separate ballast to power it as well. You can use an HID.
HogPro is offline
post #5 of 5 (permalink) Old 11-20-2013, 10:54 PM
fragmentum's Avatar
Thanks Charlie
Charlie, No, you cannot install an HID bulb in your housings without installing an HID system that does use a ballast to power the HID bulbs. Best bet without the cost of the Harley Daymakers is to upgrade your H4 bulbs to PIAA SUPER PLASMA GT-X bulbs. Retail at $49.95 each and I have a pair you can have for $35 each... If ya want 'em.
Just send me a PM...
If your not living on the edge, you're taking up too much room...
fragmentum is offline
Fuel Moto LED H4 Headlight Replacement Bulbs redbaron Lighting 2 01-13-2015 01:36 PM
PIAA Replacement Bulbs mdwar2005 Lighting 2 05-30-2011 07:21 AM
silverstar bulbs Clyde Lighting 6 08-31-2010 01:36 PM
Colored Bulbs for Gauges METIME Lighting 2 08-24-2010 01:06 AM
Replacing my headlight bulbs........ ybnorml *General Road Glide Discussions/Pictures 3 03-28-2010 08:40 AM
