Foot control extension - Road Glide Forums
post #1 of 11 (permalink) Old 11-27-2013, 09:32 AM Thread Starter
Hey all, I'm new RG owner and trying to make some adjustments. Thanks in advance for taking the time to check this post out.
How big a deal (DIY vs Pro) is it to extend the lower controls on my '06 RG? I'm 6'5 with a 34" inseam, so as it sits right now, my toes end up under the rear brake pedal by a couple inches. Any suggestions would be much appreciated.
bgjhnsn4259 is offline
post #2 of 11 (permalink) Old 11-27-2013, 10:49 AM
turbochrisb's Avatar
Nothing constructive to add cept to say the bikes looking GOOD. Loving the blacked out bits.
turbochrisb is offline
post #3 of 11 (permalink) Old 11-27-2013, 12:05 PM
quikcarl61's Avatar
You could look at the Harley extended reach brake lever, its about an inch longer than stock, so it would move the pad forward a little bit. Also Kuryakyn makes a floorboard relocation kit that moves the driver boards forward and out 1 inch, very easy install. On the shifter side, again Harley has the extended reach shifter levers that will give you some room forward and aft. Hope some of this helps, let us know what you decide. I should add, if you decide to purchase any of these parts, find PcPain on the boards for your best deal.
quikcarl61 is offline
post #4 of 11 (permalink) Old 11-27-2013, 12:24 PM
teejay's Avatar
+1 on the extended reach brake pedal.
tj
teejay is offline
post #5 of 11 (permalink) Old 11-27-2013, 12:28 PM
Fenny's Avatar
+2 on the Kury extended brake pedal and footboard extensions. I think the Kury pedal is a little further forward than the HD one.
Kury also makes extended shift levers which are also longer than the HD ones. I believe the HD shift levers are 1" longer than stock (each lever - sold as a kit) and the Kury levers are 1 1/2" longer than stock.
2004 FLTRI - Custom Paint: Glacier White Pearl & Vivid Black with Blue Flake, 12" Buky Malos, Dragos Dragula, Monroe DIY Air Shocks
2001 XLH1200 - Black & Chrome
Fenny is offline
post #6 of 11 (permalink) Old 11-27-2013, 01:02 PM Thread Starter
That's a huge help! How complex is the install? I'm somewhat mechanical, but zero experience on motorcycles specifically.
post #7 of 11 (permalink) Old 11-27-2013, 01:23 PM
Fenny's Avatar
Shifter levers are easy, one socket head machine screw in each - slide em off the shaft and replace with new.
Brake lever is pretty easy too, but requires removal of the foot board. Still just a handful of nuts & bolts though.
When I installed mine (both sides) I think it took less than 30min with basic sockets, wrenches, and an Allen wrench or two.
Fenny is offline
post #8 of 11 (permalink) Old 11-27-2013, 04:14 PM Thread Starter
Great, thanks a ton! Just gonna shop around and look for the combo that makes the most room.
post #9 of 11 (permalink) Old 11-29-2013, 08:42 AM
WILLIAMJRDN is offline
post #10 of 11 (permalink) Old 11-29-2013, 03:32 PM
Tall Guys
I am 6'5" with a 36" inseam and ride a 2013 RGU I installed the Kuryakyn foot board extenders. The move the boards out and forward about 1 inch. That helped a lot. But the biggest help for me was installing 14 inch Outlaz bars. They let me sit up and made the ride much more comfortable. Good Luck.
Craignjohnson is offline
SlipStream foot control collection bugsinteeth Parts for Sale 2 06-08-2016 03:28 AM
extended foot control question freeglide Controls & Handlebars 12 06-14-2013 04:19 PM
Foot control suggestions JJSW1283 Controls & Handlebars 2 11-27-2012 11:56 AM
BAG EXTENSION LED maybe a bad relay h-donut Lighting 8 10-03-2010 12:53 PM
2" extension bars for my roadie 07Roadie *General Road Glide Discussions/Pictures 2 09-24-2010 10:26 AM
