I know that there is a post about the rides while at SW, but I'll be damned if I kind find it. So on to the real question. Downloaded the rides to the usb and imported them to the bike. Instead of one ride (like the Chimney Rock) its imported it into 3 (maybe 4) separate pieces. What did I do wrong, can't seem to find the answer. Any help?
When I plan my rides I’m used to set some HD dealers as waypoints. Because of it when I import the GPX the results are separate routes for each leg, same as it happens to you.
I tried to see if it was possible to set them as pass-by points but without success.
The same thing happens when I import the GPX to my zumo for the other bike, so it is a planner issue and not a boombox problem.
Well I still don't know where the post was with the rides, BUT I found out to change the numbers for stops into waypoints and problem gone. Man.....picky picky picky
