monroe air ride & belt tension - Road Glide Forums
post #1 of 10 (permalink) Old 12-11-2013, 12:03 AM Thread Starter
been read a lot about the Monroe air ride and I think I am going to go ahead with it on my bike, just wondering how much the belt tension is affected from aired right up to aired out?
tigger26976 is offline
post #2 of 10 (permalink) Old 12-11-2013, 12:34 AM
Lowering the bike tightens the belt. So I would set it up a little lose (just a tad) at the height you will ride it the most when extended up so it doesn't stretch out the belt as much when you lay it out while parked. just my two cents
RGC Vivid Black,Yaffe extended BagsRC Components "Calypso" Chrome wheels,with matching rotors,HHI Stripper Bars,CFR Slip-Ons CAT Removed
Louster47 is offline
post #3 of 10 (permalink) Old 12-11-2013, 12:56 AM
Q-Hog's Avatar
++1. That's what I did.
Q-Hog is offline
post #4 of 10 (permalink) Old 12-11-2013, 07:01 AM
reficul's Avatar
Its the opposite bud. Lowering your bike loosens the belt. Set your belt tension where you wanna be at ride height. When you lower your bike your moving the arc closer to the drive pulley caused buy the swing arm to final drive pulley offset.
2012 Shark Face
One day he is gonna answer
reficul is offline
post #5 of 10 (permalink) Old 12-11-2013, 08:38 AM
Q-Hog's Avatar
I just adjust mine at the height I normally ride at. I don't ride it low. I just lower it when parked.
Q-Hog is offline
post #6 of 10 (permalink) Old 12-11-2013, 10:13 AM
beaud53's Avatar
is it very hard to adjust the tension of the belt?
if not then how do you do it?
2011 Sedona Orange FLTRX, PYBN OEM Monkey Bars, SE Heavy Breather, D&D 2-1 w/ ghost pipe.
"Don't ride faster than your guardian angel can fly"
beaud53 is offline
post #7 of 10 (permalink) Old 12-11-2013, 10:26 AM
Gray Beard
lundboy1's Avatar
Not hard at all ... I scribed a mark on my tension cam washers to the swing arm for a starting point , loosen the nut set the bike to my ride height and adjusted the belt to give me about 1/2" to 3/4" of deflection up and down on the belt and tightened the nut
Sent from Motorcycle.com App
" wishin' my knees were in the breeze!!!"
lundboy1 is offline
post #8 of 10 (permalink) Old 12-11-2013, 12:06 PM
Quite Easy........
Actually, it's quite easy. I invested about $30.00 in tools reviewed a couple You-Tube vidoes, read the manual. Done.
post #9 of 10 (permalink) Old 12-11-2013, 05:00 PM
Did mine a little differently. Found the point in the suspension travel where the belt was the tightest and set it for minimum deflection there. That way I know the belt would never be too tight anywhere in the travel and maybe snap or take out a bearing. 20k miles that way with no problems.
DuraGlide is offline
post #10 of 10 (permalink) Old 12-11-2013, 05:20 PM
McLuvin's Avatar
I had no luck trying to leave hard with it aired all the way out. It may look like a drag bike but your belt will skip and your friends will laugh.
excuse me while I whip this out...
McLuvin is offline
Drive belt tension Morningwood Do-IT-Yourself 2 03-12-2018 09:06 AM
Drive belt tension Chuck1073 *General Road Glide Discussions/Pictures 9 10-18-2016 10:03 PM
Drive Belt Wont Hold Tension adrenilinecrash Wheels and Tires 17 04-02-2013 12:42 AM
belt tension, axel torque?? kentucky cowboy Wheels and Tires 6 03-31-2013 11:00 AM
Drive belt tension avidcycler Tech Area 2 01-29-2013 11:23 PM
