Progressive Drop In Front - Road Glide Forums
post #1 of 27 (permalink) Old 08-24-2011, 06:14 PM Thread Starter
SmokinToad's Avatar
After searching, I notice many have installed the Progressive Mono Tubes in the front, but was curious if anyone has / had the "Drop In" fronts -1" #10-2003 @ MSRP of $129.95.
2009 FLTR Mirage Orange
2007 Nightster Silver / Black Denim... SOLD
SmokinToad is offline
post #2 of 27 (permalink) Old 08-25-2011, 10:06 AM Thread Starter
SmokinToad's Avatar
So nobody has an opinion on Progressive's Drop-In vs. Monotube?
post #3 of 27 (permalink) Old 08-25-2011, 03:32 PM
Not_A_CVO's Avatar
This is only a lowering kit. None of the valving or spring rate is inproved. I would almost say the ride will look cool being lowered but will ride harsher.
Not_A_CVO is offline
post #4 of 27 (permalink) Old 08-25-2011, 07:30 PM Thread Starter
SmokinToad's Avatar
The shows a progressive rate spring and 'soft' helper spring, plus PVC spacer. Gotta be better than stock spring.
post #5 of 27 (permalink) Old 08-25-2011, 08:21 PM
zman's Avatar
Installed the drop ins on the wifes 06 EG. Lowered it 1". I would describe the ride as firm but not harsh. I actually prefer the ride over the stock set-up. She complained about the ride at first but has seemed to have gotten use to it. Her biggest complaint has been handling in the curves. However I have ridden it and it feels really good to me. I've had no experience with the mono-tube. I'm planning on lowering the RG this winter do to the 21"er up front, so I'm asking the same comparison questions. Price is definitely a factor. I've been thinking about sending her seat to Mean City to have it lowered and going back to the stock springs and putting her drop-ins in the RG.
"I Just Cant Leave Well Enough Alone"
zman is offline
post #6 of 27 (permalink) Old 08-29-2011, 02:30 PM
tj316's Avatar
I ran it in the last bike , it rode better than stock , changed it over to monotubes when they were released and I liked the monotubes much better , firmer , better handling
tj316 is online now
post #7 of 27 (permalink) Old 09-01-2011, 09:48 AM
JuicedHD's Avatar
I've purchased my drop in kit but have not installed it yet. I was waiting to get new wheels before I put them in.
I may go ahead and install them anyway because I like the look with the bike a front end a little lower. Especially since I have lower shocks in the back.
I've heard that they are better than stock, but definitely not as good as the monotubes. But that's what I've heard, not based on any experience....
2009 - FLTR - SE 110, RC Componets slip-ons, Alpine/Polk/HAT/RF audio, RC Component Imperial Wheels 21/17 combo, 12” DNA Monster bars, TopShop rear fender and bags, More to come... JuicedHD...
JuicedHD is offline
post #8 of 27 (permalink) Old 09-01-2011, 02:11 PM
Xaran's Avatar
Im not a big fan of the "Drop In "system. In reality it is just a controlled spring sag to lower the overall lenght of the suspension. A lot of the guys on the Softail sites were using them but when i lowered my fatboy i choose to go with the traditional way by adding the 2" spacer spring at the bottom of the damper to limit the fork extention instaed of using the Drop in springs. Whai i have found is the Drop In set up makes a more spongy front end then doing it the traditional way because you can not preload for riders weight correctly, the more you preload (longer spacer) the less drop you have (forks extend).
I think the best way to lower it and improve the handling is the monotubes
Xaran
Previous HDs
2004 Road King Custom - SOLD
Xaran is offline
post #9 of 27 (permalink) Old 09-08-2011, 10:26 PM
RobRG07's Avatar
Progressive mono tube
the ride over stock and even the progressive lower spring kit can not be compared. the ride is way better and handling is also significantly improved. the stock suspension is horrible, period. Oil bath technology from the 50's
RobRG07 is offline
post #10 of 27 (permalink) Old 09-09-2011, 01:58 AM
Shark daddy's Avatar
I have the cartridges and lowered the front two inches. Also, i installed the Progressive 941 rear shorter shocks and the bike corners great. With the two inches in the front it does ride a lot firmer, but I like that. I have a 2011 RGU and the stock set up was a little tall for my 30 inch inseam and this with the Mean City Cycles seat lowering by an inch and back an inch and a half now has me dialed in for comfort. With the seat mod I had to install Heritage bars to be able to reach the grips, well worth the money to achieve comfort. Just a note, if you lower the bike like I did the floor board extensions do not work. I tried them and rubbed too much in the corners. I should have realized that before I installed the extensions.
Shark daddy is offline
110 drop in, CVO w/Mods, 117 drop in Lou Dude Dyno Results 1 03-08-2017 08:59 AM
Drop-in kit, is it really a drop in? Transporter Suspensions 10 01-29-2015 01:22 PM
drop front fender or go bigger front wheel? ccallahan Wheels and Tires 2 12-28-2014 10:50 PM
Photo Request: FLRTX with Progressive 1" & 2" Front Drop cyclescoot Suspensions 11 07-20-2012 10:25 AM
Progressive "Drop in lowering kit" roadglide007 Suspensions 2 09-08-2011 11:37 PM
