Monotube help... - Road Glide Forums
post #1 of 31 (permalink) Old 12-27-2013, 01:11 PM Thread Starter
StrokerAce's Avatar
Monotube help...
Ok, the wording on these instructions are a little goofy. I purchased the 1 to 2 inch drop, if I want to drop 1 1/2 inches how many spacers and or springs do I use? Anyone know? The instructions make it sound like I am adding spacers but that doesnt seem to make sense if I want to lower it.
2009 Road Glide Vivid Black
StrokerAce is offline
post #2 of 31 (permalink) Old 12-27-2013, 02:09 PM
Stag556's Avatar
I'm not sure about 1 1/2" but in my experience and research, I wouldn't go lower than 1". I bottomed out immediately leaving my garage with -2". I called progressive and they proceeded to tell me that -2" is more for show than go. They recommend nothing more than -1" for riding on all types of roads.
Some ppl will say -2" is fine but just figured I'd share my experience. -1" was three c clips and 1 long spring on the bottom.
Stag556 is offline
post #3 of 31 (permalink) Old 12-27-2013, 02:36 PM
FrankieB's Avatar
If you are doing a two inch drop you use the stock top out spring along with the one in the kit and no spacers.
06 RK
11 RGU
FrankieB is offline
post #4 of 31 (permalink) Old 12-27-2013, 02:41 PM
RichieRich's Avatar
As far as I know it's either 1" or 2". Never heard of anything else with this kit. If you did it, you would be doing something custom. Whatever idiot at progressive said it was for show and not go is just that...an idiot. Mine goes pretty good -2
Sent from Motorcycle.com App
2013 BBP FLTRX
RichieRich is offline
post #5 of 31 (permalink) Old 12-27-2013, 02:56 PM
Stag556's Avatar
Well I did the install twice, double checking all my work so my install was sound. At -2", I bottomed out on the slightest bump in the road. An absolutely terrible ride.
Even had the progressive tech on the phone with me the second time through, he was very nice and helpful.
At -1", my bike rides great.
Stag556 is offline
post #6 of 31 (permalink) Old 12-27-2013, 03:39 PM
RichieRich's Avatar
How much do you weigh? I'm only like 175. That could be your issue too. Every bike is different though I guess. Mine smashed the crash bar into the fender -2 but Sic's never did. If you like it that's all that matters
2013 BBP FLTRX
post #7 of 31 (permalink) Old 12-27-2013, 03:42 PM
I weigh a little over 200lbs running -2" over 25k miles, no problem here.
Sent from my SPH-L710
post #8 of 31 (permalink) Old 12-27-2013, 03:51 PM
Stag556's Avatar
I'm about 205lbs. I can't really explain why it rode like that.
Worked out in the end so I can't complain.
To the OP, sorry to hijack the thread. Just my opinion, but I would go -1" or -2". I wouldn't start messing with .5" increments
Stag556 is offline
post #9 of 31 (permalink) Old 12-27-2013, 04:07 PM Thread Starter
StrokerAce's Avatar
Dropped the rear 1.5 with new progressive 11.5 shocks, so Im a little unsure as to how low to go on the front..
post #10 of 31 (permalink) Old 12-27-2013, 04:36 PM
JJSW1283's Avatar
-2", 250lbs on a 21". Never bottomed out.
JJSW1283 is offline
Progressive monotube story BLACKHAWK Suspensions 1 11-07-2011 12:42 AM
progressive monotube cartridge system THEMASTERDESTROYER Suspensions 3 09-25-2011 09:57 PM
Progressive monotube on RGU jupiter Suspensions 11 09-08-2011 09:58 PM
Progressive Monotube bigbrainbob Suspensions 12 04-23-2011 04:32 PM
Proggressive Suspension Monotube Kit akjeff *General Road Glide Discussions/Pictures 6 07-30-2010 10:47 AM
