Front fork help - Road Glide Forums
post #1 of 8 (permalink) Old 01-07-2014, 09:38 PM Thread Starter
FlatOut's Avatar
Front fork help
I am installing 21" wheel, new sliders and monotubes.. All are done and ready to reinstall, while putting forks back into trees the forks hit upper trees as if they are not aligned. I have traced it back to when I installed the riser bushing while everything was off. So how do I realign top and bottom trees?
2012 RGC - Work in progress
FlatOut is offline
post #2 of 8 (permalink) Old 01-07-2014, 09:47 PM
bpt-bagger's Avatar
You removed you're trees to install riser bushings? You don't have removed you're you're trees to install any of the parts you mentioned. Need more info to steer you in the right direction.
bpt-bagger is offline
post #3 of 8 (permalink) Old 01-07-2014, 10:06 PM Thread Starter
FlatOut's Avatar
No trees removed but when I was installing riser bushings while my forks were out of trees they might have got tweaked. This is the only thing I can think of, the trees don't line up they are slightly off and I can't get forks back in they bind. While forks are out there is nothing to keep the alignment of upper and lower trees, right?
FlatOut is offline
post #4 of 8 (permalink) Old 01-07-2014, 10:07 PM
Loosen the steering head bearing bolt and orient the top tree with the bottom. Then tighten it back up.
HogPro is offline
post #5 of 8 (permalink) Old 01-07-2014, 10:11 PM Thread Starter
FlatOut's Avatar
Thanks brother what size is that bolt/nut? I can research if you don't know off the top of your head.
FlatOut is offline
post #6 of 8 (permalink) Old 01-07-2014, 10:13 PM
bpt-bagger's Avatar
If you don't know how to properly adjust you're fall out I wouldn't.
post #7 of 8 (permalink) Old 01-07-2014, 10:17 PM
Big. I dunno off the top of my head. Maybe 1.5"?
HogPro is offline
post #8 of 8 (permalink) Old 01-07-2014, 10:19 PM
Transplant's Avatar
I think it's 1 1/2" . When I had my fall away set , the tech at the dealer mentioned the size.
Transplant is offline
Wanted: Black Front Fork Air Baffle G Classifieds Archive (3 months old+) 0 02-07-2011 01:55 AM
Front end dive and fork oil 96349 *General Road Glide Discussions/Pictures 5 05-19-2010 05:38 AM
Front Fork Clunking Noise joke *General Road Glide Discussions/Pictures 12 05-01-2010 09:22 AM
Front fork axle stud replacement kimmer127 Troubleshooting for Road Glides 0 04-08-2010 06:35 PM
