Monotube spacer alternatives??? - Road Glide Forums
post #1 of 4 (permalink) Old 01-10-2014, 07:28 PM Thread Starter
Is there anything that can be used as an alternative to the c-clips? How about a certain diameter piece of pvc?
Thanks!
Wesley
2012 Road Glide Custom
Cut, raked and stretched rolling on a 26!
W_D_R is offline
post #2 of 4 (permalink) Old 01-10-2014, 07:39 PM
ERod62's Avatar
Are you try Progressive if available.
Will not rig up my suspension and risk safety.
Sent from Motorcycle.com App
ERod62 is offline
post #3 of 4 (permalink) Old 01-10-2014, 09:10 PM
Banned
Suppose you could make something exactly like the C-clip but why? It has to be a C to fit around the shaft then the fork tube holds it in place... But to answer your question directly No pvc will not work.
SlowGuy is offline
post #4 of 4 (permalink) Old 01-12-2014, 10:46 AM
SmokeyJoe's Avatar
I have some extras, just let me know and i can send them.
SmokeyJoe is offline
Monotube spacer question SmokeyJoe Suspensions 4 12-12-2013 04:12 PM
legit and legal CABLE alternatives h-donut General Off-Topic Discussions 25 02-17-2013 11:24 PM
Poker run alternatives TracyB General Off-Topic Discussions 16 01-14-2013 07:59 PM
air pump alternatives? DWyellowRG Suspensions 10 06-05-2012 07:08 PM
