Another Race Tech Question - Road Glide Forums
post #1 of 5 (permalink) Old 01-14-2014, 08:44 PM Thread Starter
Indy installed the race tech suspension kit with gold emulators lowered 1 inch. It looked lower to me and bottomed out alot. when I measured it was 2 inches lower. I took it back and he is going to check it out but he is certain he only added the 1 inch rebound spring to the damper rod provided in the kit and discarded the stock damper spring. Do you guys have any other ideas. Sorry for the questions but suspension is not my cup of tea.
jlittle1274 is offline
post #2 of 5 (permalink) Old 01-14-2014, 08:57 PM
Did you buy the lowered kit which includes a lowered main spring plus a lowered topout/rebound spring?
You also may need to change the weight of the fork oil.
post #3 of 5 (permalink) Old 01-14-2014, 09:07 PM Thread Starter
The Indy ordered the kit for me so I not sure. The fork oil was 20 wt
post #4 of 5 (permalink) Old 01-14-2014, 09:16 PM Thread Starter
I'll check with the Indy in the am on the kit. I assumed it was the high performance kit with stock spring. I think the kit said it could lower 1 to 2 inches max
post #5 of 5 (permalink) Old 01-22-2014, 01:58 PM
Xaran's Avatar
How much SAG is in the fork? If you are off the bike and try to pick up on the forks , are they topped out or are they sagging a little? This is probably where why it is more than 1" lower. Have your mechanic set up the pre load to the correct amount of SAG with you on the bike.
Stock forks have about 4.6" of travel, lowered 1" makes for 3.6" (extended to bottomed) SAG should be about 1/3 of the travel (1.2") with you on the bike.
Xaran
Previous HDs
2004 Road King Custom - SOLD
Xaran is offline
Installed Race Tech 1.0 Springs with Gold Emulators RGKen Suspensions 9 01-21-2016 12:55 AM
Race Tech high performance spring kit with gold emulators jlittle1274 *General Road Glide Discussions/Pictures 17 01-20-2014 09:23 PM
race tech high performance spring kit, gold emulators jlittle1274 Suspensions 1 01-06-2014 02:54 PM
Ricor Intiminators or Race Tech Gold Valves Xaran Suspensions 5 03-05-2013 11:00 AM
Race Tech Springs and Emulators darkknight Suspensions 7 12-08-2012 10:46 PM
