-2" monotube opinions please. - Road Glide Forums
post #1 of 46 (permalink) Old 01-22-2014, 12:17 PM Thread Starter
zman's Avatar
Last weekend I installed the lowered monotubes and set them up for -2". After the fact, I did some reviewing of the forum and with all the talk of dented fenders, limited travel and dragging boards, I'm beginning to second guess myself. I was hoping for some feed back from those out there, who are in fact, running or have ran in the past the -2" monotubes as in likes, dislikes or do-overs. "What's the likely hood of denting my fender?" That's my greatest concern. Is it really worth going -2" purely for the look? Or is -1" the way to go for a daily rider?
I value the words of experience.
Thanks, Z
"I Just Cant Leave Well Enough Alone"
zman is offline
post #2 of 46 (permalink) Old 01-22-2014, 12:29 PM
McLuvin's Avatar
Zman,
My monotubes really are in the mail. After reading through thread after thread on here I am going with the 1" drop. I love the low look and have the Monroe kit in the back but I don't like bottoming out. Let me know which way you end up going I'm following. Thanks for the info.
McLuvin
excuse me while I whip this out...
McLuvin is offline
post #3 of 46 (permalink) Old 01-22-2014, 12:33 PM
JayKS's Avatar
Subscribed. I'm going through the same process, only I have the luxury of first guessing myself since I haven't installed them yet.
Sent from Motorcycle.com App
JayKS is offline
post #4 of 46 (permalink) Old 01-22-2014, 12:51 PM Thread Starter
zman's Avatar
Lol, Why can't I learn to do that. I tend to jump first then ask about the alligators.
zman is offline
post #5 of 46 (permalink) Old 01-22-2014, 12:58 PM
For what its worth, i debated this too. Just installed mine last week and went -1. Set it on the ground for the first time monday and that thing is LOW. I still can't seem to understand the mechanics of how the system works, that not adding the second spring and adding preload adjusters would make it taller... but it's pretty low now with -1. And I think that largely has to do with most running -2 have a 21" wheel which is taller by over an inch.
I know that doesn't answer your question on the dented fenders, but I guess where i'm going with that is the -1 is more like -1.5 and you should eliminate the risk of hitting your fender. I'm glad I didn't go lower because mine would be going down hill. I almost put in another preload clip to bring it up a 1/4 inch per progressives instructions.
Halstem1 is offline
post #6 of 46 (permalink) Old 01-22-2014, 01:15 PM
I installed mine at -1" and find it's pretty low. I used the HD lowering front end kit on my wife's Road Glide Custom which is -1" and mine is lower than hers. I would have used the HD kit but Harley does not make a kit for the CVO forks. To me, the HD lowering kit rides better than these progressive monotubes do. I put 50,000 miles on my 2011 with the HD front lowering kit, in my opinion the ride was better than the ride with these monotubes.
FireBall is offline
post #7 of 46 (permalink) Old 01-22-2014, 01:23 PM
Been running -2" for over 3 years now, no dented fender or any other issues.
Sent from my SPH-L710
post #8 of 46 (permalink) Old 01-22-2014, 01:31 PM Thread Starter
zman's Avatar
If you get a chance, I'd be interested in knowing the distance from the bottom of the weld on your upper engine guard bracket to the top of the fender parallel to the forks.
zman is offline
post #9 of 46 (permalink) Old 01-22-2014, 01:33 PM
Been running mine for about the same time as D but I do have one dent. I hit a HUGE pothole on the interstate. The dent came from the weld that's on the middle of the crash bar. Its small and you don't notice it.
Frankie has a 2in drop on the RK and no issues with his.
post #10 of 46 (permalink) Old 01-22-2014, 01:37 PM
FrankieB's Avatar
The dent usually don't happen when you bottom out, it is when you bottom out from a big ass whole and the forks flex back.
06 RK
11 RGU
FrankieB is offline
Please, Please, Please don't do this... cnidog Safety Area 13 09-01-2012 10:51 AM
Some opinions, please? TDavis Windshields 8 01-08-2011 08:47 AM
Opinions Please--2006 RG houstonhdguy *General Road Glide Discussions/Pictures 13 11-13-2010 11:11 PM
Opinions please. Brad Thrash *General Road Glide Discussions/Pictures 15 10-12-2010 10:12 AM
