Fork cap size? - Road Glide Forums
post #1 of 3 (permalink) Old 09-28-2011, 07:44 PM Thread Starter
Fork cap size?
Is it 1 3/8 ???
THEMASTERDESTROYER is offline
post #2 of 3 (permalink) Old 09-29-2011, 07:12 AM
FrankieB's Avatar
not sure on the size, but i think it would require a speciality socket with the rounded corners. I use a 10 or 12 inch adjustable wrench to take them off.
06 RK
11 RGU
FrankieB is offline
post #3 of 3 (permalink) Old 09-29-2011, 09:37 AM
I have used the 36mm rear axle nut wrench to get them off. I think a 35mm would fit perfectly but the 36mm with a wrap of black tape around the nut works perfect.
jeff is offline
front fork cap, is it metric? Beaver Suspensions 1 03-22-2018 06:51 PM
Front Flush Mount Axle End Cap (the bottom cap) Dmize Wheels and Tires 3 09-18-2014 05:54 PM
Size of solid cap after removing stock shocks Sikk1 Suspensions 3 09-19-2012 08:04 PM
Fork cap bolt removal hognut Suspensions 30 05-18-2012 05:06 PM
Socket size for fork caps x52gnr *General Road Glide Discussions/Pictures 1 03-02-2012 10:31 AM
