Air ride - Road Glide Forums
post #1 of 3 (permalink) Old 10-06-2011, 11:28 AM Thread Starter
Air ride
I read an artitical air ride with the small compressor mounter in the saddlebag that keeps air in your shock at a set psi and you can lower the bike and raise it as needed or wanted. I believe it was also connected to the jiffy stand. Anyone have any experience with these?
Jerry King
USMC MSgt Ret.
kingjj is offline
post #2 of 3 (permalink) Old 10-06-2011, 09:24 PM
thedude's Avatar
Legend out of Sturgis makes air ride shocks with a button mounted on the handlebars to you can pump them up on the fly. I have looked at them and from what I have heard they have a good rep but they run about $1600.
thedude is offline
post #3 of 3 (permalink) Old 10-06-2011, 10:20 PM
I have as set of Arnotts on mine. I mounted the compressor under the battery and wired the switch into the PTT switch on my left handlebar. Also installed a gauge which gives me an indication on where to run the pressure as I am always changing it for soft ride or lowering for in the city for handling.
kruzin is offline
Arnott Releases Video Highlighting Ultimate Ride and Smooth Ride Air Suspension Kits ArnottInc Suspensions 0 04-18-2017 10:41 AM
diy air ride.. Gabriel PSI and Ride Height Q Cudaman Suspensions 8 07-16-2014 03:48 PM
Air Force Air Cleaner & Timer Cover - New Sealed Shrug Classifieds Archive (3 months old+) 0 07-02-2010 09:26 AM
