Progressive Monoshock - Road Glide Forums
post #1 of 11 (permalink) Old 10-07-2011, 01:05 PM Thread Starter
1BigGuy's Avatar
Just a question to see if anyone out there who has replaced their standard front shock with a lower Progressive Monoshock has had any issue with brakes after the install. Being told by the Stealer that they cannot figure out the brakes pulling to the right issue, but since it started when the monoshocks where installed they think it's that. They want me to pay for them to investigate?? They installed the shocks, whatever happened to a guarantee of work performed? Time to find a good indy in the area.
2010 FLTRX Black Denim
2007 FLSTN Vivid Black
1BigGuy is offline
post #2 of 11 (permalink) Old 10-07-2011, 02:48 PM
FrankieB's Avatar
no issue with them on the wife's bike,but i would take a look at the caliper and make sure the rotor is spaced evenly and check the axle alinement with a drill bit. If the rotors are not evely spaced they could have put a spacer on the wrong side.
06 RK
11 RGU
FrankieB is offline
post #3 of 11 (permalink) Old 10-07-2011, 02:55 PM
Shark daddy's Avatar
I had the install done a year ago and no brake issues after 10,000 miles. Something is screwy with the brakes I'm sure unrelated to the actual inserts.
Shark daddy is offline
post #4 of 11 (permalink) Old 10-07-2011, 03:14 PM
tdkkart's Avatar
Did they bother to tighten the legs back in the triple trees when they put them in??
tdkkart is offline
post #5 of 11 (permalink) Old 10-07-2011, 03:18 PM Thread Starter
1BigGuy's Avatar
Thanks Frankie, they said they checked the rotors and axle and saw no issue. I don't believe there is anything wrong with the progressive mono. I believe it has mote to do with the reinstallation of the wheel and rotors. The short of it being a bad install. Was not able to talk to the service manager or the GM. Waiting on their survey call I get after every time it's in there to blast them. It's the only thing that seems to get action from the service department.
1BigGuy is offline
post #6 of 11 (permalink) Old 10-07-2011, 04:48 PM
November will make a year since I've had my monotubes, (-2") no issues at all.
post #7 of 11 (permalink) Old 10-07-2011, 05:26 PM
I did my FLTRSEI2 '01 for my wife. Everything worked out fine. Rear brakes didn't work worth a crap. Scratched my head. I finally took it to a dealer. I had lowered the rear end as well 2" all around. Front brakes were fine.
Turns out I used a several year old bottle of DOT 5 in the rear caliper. It was clear not purple. New brake fluid fixed the problem. I know it's a stretch. Had it not happened to me I never would have believed it.
According to them my alignment was perfect.
Frankly, I can't wait to put new legs all the way around my '11 FLTRUSE. The stock suspension is complete junk.
FGOWI is offline
post #8 of 11 (permalink) Old 10-07-2011, 10:44 PM
klyons8963's Avatar
No problems
I did the progressive monotubes on my 2012 RGU. I have not experienced anything negative from this install. I also did the 1" shorter shocks at the same time. It lowered the front end about an inch and a half and the back about one inch. This made the bike sit more level. Today a guy pulled out in front of me, I was going 65 mph and had to really get on the brakes. I noticed very little nose dive and never had the ABS kick in. I really believe if I had been on my last bike (2006 Superglide) I would have hit him or laid it down. I have yet to experience anything negative with the monotubes.
2012 RGU Vivid Black
Vance and Hines Dresser Duals
Hi output mufflers
Heritage Bars
Progressive Mono-tubes
1" shorter rear shocks
klyons8963 is offline
post #9 of 11 (permalink) Old 10-12-2011, 08:39 PM Thread Starter
1BigGuy's Avatar
Got the survey call tonight. Now lets seem if the GM calls me tomorrow.
1BigGuy is offline
post #10 of 11 (permalink) Old 10-12-2011, 09:12 PM
abone's Avatar
Send a message via Yahoo to abone
Had a bad experience when I bought my bike including spending $20,000 (cdn) in mods to boot. Dealer survey shows up in the mail, I wrote some very direct comments and included my name, and phone #'s on the survey form, and asked them to call. Guess what, never a word from HD or the dealer. Hope you have better luck.
2010 RG
abone is offline
Progressive monoshock and 26" wheel 1CoolZ71 Suspensions 18 07-22-2014 04:42 PM
Monoshock Noise? Hunter 1 Suspensions 7 08-22-2013 03:40 PM
Progressive 940 Shocks FreeBird *General Road Glide Discussions/Pictures 6 09-19-2010 04:42 PM
Progressive Shocks 1814 *General Road Glide Discussions/Pictures 15 09-12-2010 02:26 PM
Anyone riding on Progressive 416's? RoadGlide0611 Aftermarket Accessories 0 08-25-2010 11:16 AM
