Monotubes - Road Glide Forums
post #1 of 6 (permalink) Old 02-03-2014, 07:01 PM Thread Starter
Monotubes
I am sure this has been answered some where in here but after searching around I could not find the answer. Can you run the monotubes with -2 with a stock tire/rim? Reason I ask is I'm switching my forks/cowbells to black and going to install the monotubes at the same time but don't have the funds yet for the 21" wheel I want. Just dont want to have to go back and redo the monotubes if I don't have to
2012 RG FLTRX MGS pipes, 21" HogPro Vivid Black Shelby w/LRB rotors, KW Wrapper Fender,Mustang wide tripper solo, PY 14" monkey bars, CD plasma rods
Jasondoow is offline
post #2 of 6 (permalink) Old 02-03-2014, 07:08 PM
RichieRich's Avatar
Yes you can
Sent from Motorcycle.com App
2013 BBP FLTRX
RichieRich is offline
post #3 of 6 (permalink) Old 02-03-2014, 07:35 PM
Willy_B's Avatar
Yes you can. I did for a month or so while my wheel got rechromed. ImageUploadedByMO Free1391474087.324190.jpg
Willy_B is offline
post #4 of 6 (permalink) Old 02-04-2014, 05:04 PM
...and it doesn't ride too bad at all, just scrapes the boards a bit.
2013 FLTRX Candy Orange 107 57H cams, Heads, V&H Monster Rounds, Jackpot header, Powervision, V&H VO2 intake, Daymaker LED headlights, 12" Buky Malo V1 bars, Self-painted inner fairing, Plasma Rods, Arlen Ness fire ring LED signals, Wind Splitter shield, J&M speakers, Rockford Fosgate amp, stock speakers installed inside fairing, DIY air ride suspension, Mono tube forks
mffi497 is offline
post #5 of 6 (permalink) Old 02-23-2014, 04:07 PM Thread Starter
Got the monotubes installed (-2) and I noticed it's hard to put the kickstand down now. Do they make shorter ones or what's some alternatives??
post #6 of 6 (permalink) Old 02-23-2014, 05:14 PM
Q-Hog's Avatar
Put a couple thin washers on the bottom two kickstand bolts, that should do the trick. $0.25 fix.
Q-Hog is offline
Monotubes with a 21 inch front wheel 2012 RGC CVO Cmathias Suspensions 7 07-23-2012 11:18 PM
Monotubes or dropin springs Koda1975 Suspensions 8 03-08-2012 12:49 AM
Fork upgrade: progressive spring vs monotubes ilmanzo31 Suspensions 8 03-05-2012 12:37 PM
progressive monotubes THEMASTERDESTROYER Suspensions 0 03-03-2012 06:27 PM
Installing progressive monotubes how to?? jbrawkus Suspensions 6 12-12-2011 05:16 AM
