Raise Bike Up? - Road Glide Forums
post #1 of 16 (permalink) Old 02-12-2014, 06:17 PM Thread Starter
Raise Bike Up?
I would like to raise my bike up an inch or so front and back, stock wheels. Any recommendations on the best way to do this if it's even possible? Thanks.
Rambo
2012 Road Glide Ultra
Rambo is offline
post #2 of 16 (permalink) Old 02-12-2014, 06:26 PM
Fenny's Avatar
Raise it? There's something you don't hear everyday...
I'm not certain, but I believe a 21" front rim will raise the front about 1.25" or so. As for the rear, I think progressive makes some 14" shocks ( you're stock shocks should be 13"). Also, the DIY Monroe air shocks are 14" fully extended.
Edit: just checked progressive suspensions website, looks like the longest they make is 13.5".
2004 FLTRI - Custom Paint: Glacier White Pearl & Vivid Black with Blue Flake, 12" Buky Malos, Dragos Dragula, Monroe DIY Air Shocks
2001 XLH1200 - Black & Chrome
Fenny is offline
post #3 of 16 (permalink) Old 02-12-2014, 06:43 PM
ERod62's Avatar
Raise Bike Up?
Not aware of raise kit but 21 front and 18 rear will increase diameter from stock tires.
Wonder how will handle higher of the ground. A friend didn't lower the front after installing a 21" they like it.
ERod62 is offline
post #4 of 16 (permalink) Old 02-12-2014, 08:15 PM Thread Starter
Thanks for the quick replies. I'll dig a bit deeper into the larger wheels and air shock options.
Rambo
Rambo is offline
post #5 of 16 (permalink) Old 02-13-2014, 09:07 AM
93-331-29psi's Avatar
Ok, since nobody asked I will..... Why would you want to raise it?
93-331-29psi is offline
post #6 of 16 (permalink) Old 02-13-2014, 09:21 AM
RichieRich's Avatar
What year and model?
Sent from Motorcycle.com App
2013 BBP FLTRX
RichieRich is offline
post #7 of 16 (permalink) Old 02-13-2014, 10:07 AM
Rambo,
I went with an 18" stock rear wheel, and 13.5" Progressive rear shocks. You can't really go much longer on the shock, as you will begin to run into clearance issues between the axle nuts, and your mufflers. Didn't raise the front, just went with Progressive Monotubes(stock height). More suspension travel would be nice, but it is, what it is.
Jeff
akjeff is offline
post #8 of 16 (permalink) Old 02-13-2014, 10:31 AM
RGKen's Avatar
I don't believe an 18" rear wheel will raise the bike unless you find a tire that actually has a larger outside circumference. The only tires for my 18" rear agitator that I am aware of all have very similar outer circumferences as the stock 16" that was on my last bike.
2018 FLTRXS
RGKen is offline
post #9 of 16 (permalink) Old 02-13-2014, 11:09 AM Thread Starter
I'm 6'6" and don't like to bend my knees so much - feels like a scooter sometimes. Also it keeps the less vertically inclined from asking to ride it.
But I do like the cornering with the weight down low.
Rambo
Rambo is offline
post #10 of 16 (permalink) Old 02-13-2014, 11:10 AM Thread Starter
Rambo is offline
Raise Front Fairing for Lowers dinggus Equipment-RG 15 03-05-2014 12:02 PM
Why do they raise the redline? DeneFLHR ECM/Fuel Management systems 4 12-30-2012 10:16 AM
Shocks to RAISE the rear? FLIronButtRider Suspensions 7 11-04-2012 11:35 PM
KObalt jack won't raise up from lock position jimmyray11349 *General Road Glide Discussions/Pictures 3 11-04-2011 09:19 AM
