What fork oil to you like? - Road Glide Forums
post #1 of 13 (permalink) Old 10-27-2011, 10:45 AM Thread Starter
I've never seen a fork oil argument, so I'm gonna ask--when I replace my fork oil, what's a good brand/weight/grade to replace it with? Is there a fork oil equivalent of Redline Shockproof gear oil?
FWIW, my bike gets ridden and does not sit in the garage waiting to have its picture taken so I need something that will hold up.
SickRick is offline
post #2 of 13 (permalink) Old 10-27-2011, 04:29 PM
cestaro's Avatar
Thumbs up
screaming eagle fork oil
cestaro is offline
post #3 of 13 (permalink) Old 10-27-2011, 04:32 PM
Bull_Duck's Avatar
+1 screaming eagle
Bull_Duck is offline
post #4 of 13 (permalink) Old 10-27-2011, 04:36 PM Thread Starter
Is there something quantifiable that makes it better, or is it because it has HD on the label?
SickRick is offline
post #5 of 13 (permalink) Old 10-27-2011, 05:16 PM
FrankieB's Avatar
i use SE because it is easy to get. I have also used racetech.
06 RK
11 RGU
FrankieB is offline
post #6 of 13 (permalink) Old 10-27-2011, 05:18 PM
BigDaveOnBass's Avatar
Send a message via Yahoo to BigDaveOnBass
I use any forkin' oil I choose! (Again, saw an opportunity to be a wise guy and ran with it.)
'04 FLTRI, originally Smokey Gold, now Vivid Black, 95", S/E forged high comp 9.6:1 pistons, Andrews 37G cams, Big Boyz heads, S/E adjustable pushrods, S/E Race Tuner, S/E Stage 1 kit, V&H Dresser Duals, S/E slip ons, H-D premium oil cooler, chromed wagon wheels, Brembo/H-D front brakes, added rear engine guards, Paul Yaffe 10" OEM Monkey Bars, detachable tour pak
BigDaveOnBass is offline
post #7 of 13 (permalink) Old 10-27-2011, 05:59 PM
cestaro's Avatar
Thumbs up
se better you will lose that bonce in the front end
cestaro is offline
post #8 of 13 (permalink) Old 10-27-2011, 06:37 PM
I lowered the front 1.5 inches and was wondering what is the best fork oil to use, I have read many post but no clear answer.
wilo007 is offline
post #9 of 13 (permalink) Old 10-27-2011, 06:50 PM
WTF = what the fork. SE here.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #10 of 13 (permalink) Old 10-27-2011, 06:53 PM
skratch's Avatar
okay, first off, you have to figure out for yourself if you are satisfied with the ride that your front end has now, and if not, why? if you feel like it is too soft, and too much brake dive, then you can replace the fork oil in there now with a heavier weight.
this can be as complicated or as simple as you like. you can go with the straight se heavy and call it a day, or you can mix it 50/50 with the stock weight and be right in the middle, or any combination thereof.
i run the se heavy, and i like it fine.
also, you don't have to go with the se oil. you can use another brand if you prefer, but you really won't notice a difference between brands of the same weight.
Type "E" is 5 weight - the lightest one
Type "B" is 10 weight
Type "screamin' eagle" is 15 weight
Type "screamin' eagle racing oil" is 20 weight ( Not intended for street bikes)
skratch is offline
If you carry on the bike , you might like this. MarkL General Off-Topic Discussions 22 04-11-2017 07:53 PM
I like the way the 30 looks like its spinning backwards.... Quicksand General Off-Topic Discussions 8 12-24-2012 02:06 PM
New Perfpormance Machine Fork Sliders, I like em! ChromeYellow67 *General Road Glide Discussions/Pictures 23 02-09-2012 01:31 PM
Fork oil change pte359 Do-IT-Yourself 15 09-14-2010 05:04 PM
Front end dive and fork oil 96349 *General Road Glide Discussions/Pictures 5 05-19-2010 05:38 AM
