take me to school - Road Glide Forums
post #1 of 4 (permalink) Old 02-23-2014, 06:24 PM Thread Starter
jaysrgu's Avatar
take me to school
fork oil change
last bike was a 91 softail,when I wanted to change fork oil I opened the drain then took off top cap,let drip overnight,put plug back in and fill with ex amount of oil.now looking at the manual for a rg it says I need to pull each tube off the bike,i need a vacuum pump,okay guys wtf, cant you just drain at bottom and fill at top?
jaysrgu is offline
post #2 of 4 (permalink) Old 02-23-2014, 06:53 PM
sj01fltri's Avatar
I take the gauge cover off and take the tops off,there may be a easier trick to it,on my 01 i would put a vacum pump on the air valve for the front tubes,and it would pull the fluid up thru the bleeder screws,after i made up a little tube assemble to srew into the lower legs.
sj01fltri is offline
post #3 of 4 (permalink) Old 02-23-2014, 07:03 PM
Originally Posted by jaysrgu View Post
fork oil change
Sure they do $$. What year ? Just do like you always done. Measure what you take out , and replace the same.
Big_gary is online now
post #4 of 4 (permalink) Old 03-02-2014, 09:10 PM
CustomGlide's Avatar
Send a message via AIM to CustomGlide
Make Sure You Work The Fork Legs Up And Down To Squeeze The Most Oil out
CustomGlide is offline
School Me On My Stock Shoes SteadyEddie Wheels and Tires 16 05-11-2016 02:09 AM
School Me you younger guys JacktheBagger *General Road Glide Discussions/Pictures 48 05-08-2016 07:31 PM
School me on these fancy "tuners" please? kyle31490 ECM/Fuel Management systems 37 04-17-2014 02:33 PM
Q Concerning Old School Pin Stripe Colors trippy57 Paint & Bodywork Section 8 05-16-2012 05:01 PM
Ole school bagger Rowdy Road Trip Discussions/Stories/Pictures 9 03-08-2011 08:05 PM
