Progressive monotube story - Road Glide Forums
post #1 of 2 (permalink) Old 11-02-2011, 09:00 PM Thread Starter
BLACKHAWK's Avatar
Question Progressive monotube story
06 RG, I install the monotube along with rear shock as well. The instruction tell you to install three of the C-clip. At the end of that it also says that you may change it also. Back to story. Took it out for a test ride everything was fine. When, I came to a stop no more nose dives. But it was just a little to stiff for me. After read a few review, I decide tear it back apart and a clip from each fork. I spoke with a tech at progressive about it. He recommend that, I use two C-clip for my weight. On top of that the rear shocks. I was trying to set the sag. I don't no if it me or my weight??? With the factory setting each are soft. Im getting a 1 3/8" of sag. Its is recommended 1 3/4" to 2". What, Im I doing wrong or need to put on a few more pounds.
B.R.N.Y.S
BLACKHAWK is offline
post #2 of 2 (permalink) Old 11-07-2011, 12:42 AM
You may want to hold off on the weight gain...I'm probably 275 and I can't get more than 1 9/16" with the preload (940's) backed all the way off. Progressive tech said 1 3/4 to 2", same as you, but then said it's good the way it is. Huh? Stiffer ride than stock and they don't absorb bumps like I hoped, but bike sure handles good. Monotubes are next, thanks for the heads-up!
G Ogre is offline
Progressive Monotube Review ironmark Suspensions 39 12-27-2013 12:24 PM
Progressive monotube dissatisfaction !!!! THEMASTERDESTROYER Suspensions 34 09-26-2013 04:56 PM
progressive monotube cartridge system THEMASTERDESTROYER Suspensions 3 09-25-2011 09:57 PM
Progressive monotube on RGU jupiter Suspensions 11 09-08-2011 09:58 PM
Progressive Monotube bigbrainbob Suspensions 12 04-23-2011 04:32 PM
