road glide rear shock oil - Road Glide Forums
post #1 of 2 (permalink) Old 03-01-2014, 11:35 PM Thread Starter
Cool road glide rear shock oil
I picked up a set of 09 up rear oem shocks for my 08 road glide, im reading about people changing the oil in them to amsoil shock therapy #10, anyone try this and get results correcting the bottoming on bumps and creating a better ride?
allfixed is offline
post #2 of 2 (permalink) Old 03-07-2014, 01:35 PM
Xaran's Avatar
There are a lot of posts on HD Forums about changing the oil and an improvement but after I swapped out mine I played with changing the oil and did not feel any difference. In general the stock shocks are a very old and basic design and the dampening in them is very limited regardless of the oil used. There may be some improvement is that heavier oil may slow the response of the shock (increase dampening).
If you go to Howards page at www.motorcyclemetal.com he used to have a good write up on this as well as a breakdown of the stock shocks so you can see how basic the dampening setup is in them.
Xaran
Previous HDs
2004 Road King Custom - SOLD
Xaran is offline
Best aftermarket (pref progressive) rear spring shock 2015 glide mh1775 Suspensions 6 06-21-2015 11:22 AM
Changed shock oil Venomized Suspensions 1 11-14-2013 08:46 PM
OEM shock leaked oil aviaator Suspensions 16 05-03-2013 04:10 PM
Lowered monotubes and shock oil hognit Suspensions 7 09-16-2012 12:21 PM
2012 Road Glide Ultra stock rear shock length? privatemc Suspensions 3 09-01-2012 10:03 AM
