Monotube questions - Road Glide Forums
post #1 of 13 (permalink) Old 03-11-2014, 04:59 AM Thread Starter
Monotube questions
I've read numerous posts re: mono tubes and I'm not questioning the improved performance received from their installation. My question(s) concern lowering. My ride is a 2012 RG custom I do not want to lose clearance when cornering. I am running stock rims and tires (size wise) and do not plan to change. Everything I've read says that even the stock height monotube drops it an inch or am I misunderstanding the use of the term lowering.
I'm 5' 10" 200 30" inseam so I can flat foot no problem, 2 up wt runs apps 350.
Aggressive cornering so even 1 up floorboards touch down.
Given all this am I making a mistake getting monotubes and if not are the 31-2500 the ones I need.
Thanks
bcultra is offline
post #2 of 13 (permalink) Old 03-11-2014, 07:05 AM
RGU72's Avatar
From what I am hearing off this forum. That part # is the kit that keeps your bike at stock height. The other kit is the 31-2501 which lowers the bike 1 to 2 inches.
RGU72 is offline
post #3 of 13 (permalink) Old 03-11-2014, 09:29 PM
CustomGlide's Avatar
Send a message via AIM to CustomGlide
I Spoke Directly To Progressive When Purchasing Mine And The Rep Told Me, Even The Stock Kit Lowers The Bike 1"
CustomGlide is offline
post #4 of 13 (permalink) Old 03-11-2014, 09:58 PM
I dont feel it lowered mine at all. I only used one spacer per side too. The kit comes with two spacers per side. Using only one per side lowered it 1/4 inch from full stock height.
post #5 of 13 (permalink) Old 03-11-2014, 10:52 PM
ERod62's Avatar
I install the stock height 31-2500 per instructions did not lower my front end at all.
Sent from Motorcycle.com App
ERod62 is offline
post #6 of 13 (permalink) Old 03-12-2014, 01:43 AM
SmokeyJoe's Avatar
I have the stock height kit installed with no c clips. This lowered the bike 1.5 inches.
SmokeyJoe is offline
post #7 of 13 (permalink) Old 03-12-2014, 07:58 AM
hometoast's Avatar
The FLTRX is an inch lower than the FLTRU anyway, yes? Perhaps progressive is going by the height of the ultra?
hometoast is offline
post #8 of 13 (permalink) Old 03-12-2014, 08:18 AM
mocotom's Avatar
Actually the front forks are identical on both models, the 1" difference is only in the rear due to shorter shocks. To the OP, with the standard monotubes and both clips installed there will be very little or no change in height when sitting static. The big difference is when you push it into that turn the front suspension doesn't compress as much as the soft stock springs so your ground clearance remains the same or better.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #9 of 13 (permalink) Old 03-12-2014, 08:23 AM
hometoast's Avatar
Thanks for the clarification.
Damn you guys and this forum... these are going on my Fall TODO list.
post #10 of 13 (permalink) Old 03-12-2014, 01:47 PM
Varied opinions on this topic... this is one of the most accurate responses. Like someone posted above, I also talked with progressive directly. To add to this... the stock height kit can be used without the c-clips and lowers the bike aproximately .5" - 1" depending on the kit. The lowering kit gives you the option of lowering, in their words "1 or 2 inches", however, the taller option lowers the bike about 1.5" from stock height. You can add a 4th c-clip (1 more than instructed but included in the kit) to raise up an extra 1/4". Or the kit can be ran at its lowest setting for a pretty accurate -2" height.
Just throwing in my 0.02$ because I installed the lowering kit for -1 and it lowered mine more than I wanted with stock wheels and tires.
Halstem1 is offline
Monotube questions Diverrick Aftermarket Accessories 12 04-11-2016 04:12 PM
A couple questions - which monotube and shock? turbochrisb Suspensions 5 04-03-2015 03:06 PM
progressive monotube install questions pimpsarus Suspensions 3 12-10-2012 03:29 PM
Lowered 2" Monotube questions Jaystew Suspensions 5 05-18-2012 05:52 PM
Proggressive Suspension Monotube Kit akjeff *General Road Glide Discussions/Pictures 6 07-30-2010 10:47 AM
