Visit 98c Compressor bracket - Road Glide Forums
post #1 of 55 (permalink) Old 03-12-2014, 08:15 PM Thread Starter
Starts out with a 3/16 thick plate with four mounting holes drilled in it
texastrendz is offline
post #2 of 55 (permalink) Old 03-12-2014, 08:19 PM Thread Starter
Then a second plate is broke at the same angle of the saddle bag support bracket
post #3 of 55 (permalink) Old 03-12-2014, 08:23 PM Thread Starter
Then they are welded together using the bracket as a jig for proper fit and alignment
post #4 of 55 (permalink) Old 03-12-2014, 08:37 PM Thread Starter
A two piece split collar is welded to the top for the upper support
post #5 of 55 (permalink) Old 03-12-2014, 08:45 PM Thread Starter
Then we drill out the lower 5/16 thru hole and finish weld it out
post #6 of 55 (permalink) Old 03-12-2014, 08:48 PM Thread Starter
The last step to this is machining the top of the two piece split collar for saddlebag clearance.
post #7 of 55 (permalink) Old 03-12-2014, 08:52 PM Thread Starter
And we have five of them done and out for gloss black powder
post #8 of 55 (permalink) Old 03-12-2014, 09:11 PM Thread Starter
Now for the compressor to fit in this location and on this bracket it has to be modified. To do this you have to trim the ears off of it and drill new mounting holes in the viair bracket. It is important to keep everything square and straight when drilling the holes.
post #9 of 55 (permalink) Old 03-12-2014, 09:15 PM Thread Starter
Ears removed. Now you will use the bracket as a template to locate the new holes and drill them out. Pretty easy and straight forward
post #10 of 55 (permalink) Old 03-12-2014, 09:18 PM Thread Starter
Drill one hole out and install bolt and nut to hold it while you drill out the remaining holes.
Viair 98c compressor mount texastrendz Parts for Sale 24 01-19-2015 10:10 PM
Detachable Upright 52627-09 & Backrest Pad 52886-98C beavis Parts for Sale 1 09-28-2013 08:53 AM
Harley shop visit Redfish-Joe General Off-Topic Discussions 9 08-06-2011 11:15 AM
Why I visit more here verse other HD forums SharkNose *General Road Glide Discussions/Pictures 6 05-29-2011 03:10 PM
A Visit by Daughter and Grandson..... Nevadasun Road Trip Discussions/Stories/Pictures 2 05-29-2011 10:30 AM
