Fork lowers and sliders changeout - Road Glide Forums
post #1 of 10 (permalink) Old 03-31-2014, 09:35 PM Thread Starter
Hello,
I have some lower forks and sliders I would like to put on but I dread taking the fairing completely apart.
There isnt a way to change the lowers and sliders without taking the fairing off is there? I am assuming I would have to expose the fork caps in order to add fork oil.
Thoughts?
pktrusty is offline
post #2 of 10 (permalink) Old 03-31-2014, 09:46 PM
93-331-29psi's Avatar
Originally Posted by pktrusty View Post
Hello,
Thoughts?
No need to take the fairing off to do the sliders. Only need to disassemble the gauge cluster from the forks.
Sent from Motorcycle.com App
93-331-29psi is offline
post #3 of 10 (permalink) Old 03-31-2014, 09:47 PM
Jetman's Avatar
You only need to remove the Speedo Nacelle. The remainder of the fairing doesn't need to come off. Remove the Fender * wheel- speedo Nacelle- loosen pinch bolts, remove fork caps- pull forks down & out (don't tip or you'll dump fluid.). Do your slider change- re-assemble..........Nice rainy afternoon project......
OH---- if you ever think of changing your cow bells, do it now...........Heck- may as well do Mono-tubes too.........LOL!!!!!
2012 - Big Blue Pearl
Heavily Accessorized.....
Jetman is offline
post #4 of 10 (permalink) Old 03-31-2014, 09:50 PM Thread Starter
Do you have a link on how to do that? I have taken the fairing apart a few times but I have never had the gauge cluster off.
If I can change the sliders without taking the fairing off the Forks shouldnt be a issue either? How do you seat the fork seal?
Joe
pktrusty is offline
post #5 of 10 (permalink) Old 03-31-2014, 09:50 PM
ERod62's Avatar
Taking fork apart don't require removing the fairing. Just the speedo cluster and handle bars.
Recommend to buy HD manual will need tq values also good info to work with.
May want to upgrade shock while is taking apart
ERod62 is offline
post #6 of 10 (permalink) Old 03-31-2014, 10:05 PM Thread Starter
I found some pictures without the gauges. Do I have to take off the ignition switch and switches to get the bottom bolts on the bar clamps?
This will be my first time doing this. Any special tools I need? I have a fork cap socket. I have a inside snap ring pliers. I have heard it can be difficult taking out the screw on the bottom on the fork.
Am I missing anything that could cause damage?
Joe
pktrusty is offline
post #7 of 10 (permalink) Old 03-31-2014, 10:20 PM
Joe
Yes ignition switch has to come out to get the nacelle off. Just be careful when disassembling the fork because everything is spring loaded and the cap has been known to fly across the garage.
post #8 of 10 (permalink) Old 03-31-2014, 10:38 PM
Do a You Tube search for "Harley Ignition Switch Removal". Video is on an 09 Street Glide. Same switch. He shows you step by step how to remove and install it using a home made tool.
As for the bottom bolt, Try breaking it loose before you loosen the pinch bolts. Just enough to know they're loose but not leaking oil all over.
Service Manual would be very helpful. Good luck.
2012 FLTRX, vivid black
sometimer is offline
post #9 of 10 (permalink) Old 04-01-2014, 03:54 AM
bikerglasses's Avatar
I bought ignition removal tool.. Was $25 shipped and I felt with all the money I was saving by doing the work myself it was worth having around. It worked great and from all the horror stories I heard on the problems reinstalling I was very happy having it. Literally was minutes reinstalling the ignition.
Here's where I bought it from;
http://www.marcparnes.com/HarleyIgnitionSwitchTool.htm
Ian -- Tucson, Arizona
- MGS True Duals, Ness Big Sucker, 12' Twin Peaks, -1" Monotubes
bikerglasses is offline
post #10 of 10 (permalink) Old 04-01-2014, 08:45 AM
McLuvin's Avatar
A member on here did a YouTube video that got me through this. His name is Norseman (formerly Greatbigdude) and if you search monotube install on YouTube its 20min. Very helpful but, you will also need a tool to reinstall the fork seals. He shows how to make one out of PVC. This seems like a lot but it's not bad with a buddy, you can do it.
Best of luck
excuse me while I whip this out...
McLuvin is offline
Stock lowers & and stock sliders neverdone Parts for Sale 0 12-27-2014 07:33 AM
WTB -Set of fork sliders and cow bells for a 2000 2013 Street Glide or Road Glide. daryl_db Wanted! (Buy or Trade) 10 03-26-2014 11:01 PM
Fork Sliders and Handlebars METIME Classifieds Archive (3 months old+) 2 08-01-2011 04:45 PM
2010 Vivid black RGC OEM fork sliders and upper covers. 2 bike Mike Classifieds Archive (3 months old+) 1 02-24-2011 10:43 PM
New fork sliders Rowdy General Off-Topic Discussions 5 11-02-2010 01:48 PM
