Progressive monotube dissatisfaction !!!! - Road Glide Forums
post #1 of 35 (permalink) Old 12-17-2011, 01:57 PM Thread Starter
Ive read all the great reviews here and elsewhere but my review is completely opposite. Installed stock height. Stock front wheel. Bottoms out upon apron entry. Hard braking dives hard. Not that stable. Potholes- forget it !!! Anyway goin with traxxion dynamics
THEMASTERDESTROYER is offline
post #2 of 35 (permalink) Old 12-17-2011, 02:07 PM
HogWild's Avatar
Doesn't sound like its installed correctly. Just sayin. That shouldn't be happening.
"No man is rich enough to buy back his past, so enjoy the moment"
HogWild is offline
post #3 of 35 (permalink) Old 12-17-2011, 02:49 PM
Sounds like you got a defective kit, or maybe installed it improperly, no way should you have the problems you are, sounds worse than stock.
post #4 of 35 (permalink) Old 12-17-2011, 04:49 PM
1BigGuy's Avatar
There were some defective ones mentioned when I investigated it. I believe if you send them to progressive they will replace them.
2010 FLTRX Black Denim
2007 FLSTN Vivid Black
1BigGuy is offline
post #5 of 35 (permalink) Old 12-17-2011, 05:35 PM
I agree. Mine don't even come close to acting the way you are describing. The nose on the bike should only go down a very little when the brakes are applied aggressively.
post #6 of 35 (permalink) Old 12-17-2011, 08:58 PM
Gotta be either a defect, or improper installation. I suspect that if you contact the P-S tech folks. they will straighten it out.
Jeff
akjeff is offline
post #7 of 35 (permalink) Old 12-17-2011, 09:27 PM
Got 'em on an '01 RG. Makes my '11 FLTRUSE suspension feel like a POS. Wait, it is!!
I be lovin' the mono-tubes. Can't think what could be wrong though. Have you gone back through all the torques?
Didn't forget to tighten the pinch bolts did you? I guess you'd be dead. Nevermind!
Good Luck.
FGOWI is offline
post #8 of 35 (permalink) Old 12-18-2011, 09:10 PM Thread Starter
installed correctly. Maybe defective !!
post #9 of 35 (permalink) Old 12-18-2011, 09:38 PM
BLACKHAWK's Avatar
How many C-clip did you install?
B.R.N.Y.S
BLACKHAWK is offline
post #10 of 35 (permalink) Old 01-22-2012, 07:13 PM
I installed a set of Progressive monotubes in my 98 RG and boy what and improvement over the old tired sloppy front suspension. Thought they were great, definitely improve the handling though The ride got a lot stiffer. I installed the two C clips per shock tube, planing to dismantle the front suspensions this winter to remove one set of the C clips (would really prefer more of a touring ride than a sport ride).
I was once a pack animal too...
redhues is offline
Progressive Monotube Review ironmark Suspensions 39 12-27-2013 12:24 PM
Progressive monotube story BLACKHAWK Suspensions 1 11-07-2011 12:42 AM
progressive monotube cartridge system THEMASTERDESTROYER Suspensions 3 09-25-2011 09:57 PM
Progressive monotube on RGU jupiter Suspensions 11 09-08-2011 09:58 PM
Progressive Monotube bigbrainbob Suspensions 12 04-23-2011 04:32 PM
