Need Help - Road Glide Forums
post #1 of 5 (permalink) Old 04-09-2014, 09:14 PM Thread Starter
motosig102's Avatar
Need Help
2012 RGC, I screwed up when I ordered my progressive 444HD and ended up getting the 13" shocks instead. So now I am 1" higher in the rear. However when my wife and I are riding I end up being back to stock RGC height. My question is two parts.
1. I plan on adding a 21" wheel at some point in the next year or so. I know this raises the front end approx. 1.25". However like I said when we are riding it drops about 1" in the rear which if I don't raise the front would in theory seem like its going to raise the front end 2.25". So do I lower the front end 1" or 2"? I don't want it to look like its doing a nose dive while the bike is sitting or being rode.
2. The stock front springs that are in there now feel like the are extremely soft, squishy, and clunky. I have been over and over with my dealer here who is not concerned with it. My question is would running a heavy weight fork oil in the front make it ride better and not be as cluncky, squishy and soft until I can do the monotubes?
motosig102 is offline
post #2 of 5 (permalink) Old 04-09-2014, 09:23 PM
93-331-29psi's Avatar
Do monotubes in a 1 inch drop and you should be golden when riding 2 up. The squishy front end will go away with monotubes as well.
Sent from Motorcycle.com App
93-331-29psi is offline
post #3 of 5 (permalink) Old 04-09-2014, 09:28 PM
As mentioned above, do the monotubes, but before you do them heavier oil up front will help in the interim, but not as good as monotubes.
Sent from my SPH-L710
post #4 of 5 (permalink) Old 04-10-2014, 04:58 AM
FrankieB's Avatar
Unless you are having footing issues with the height I wouldn't lower it. I like to keep maximum suspension travel.
06 RK
11 RGU
FrankieB is offline
post #5 of 5 (permalink) Old 04-10-2014, 05:33 PM Thread Starter
motosig102's Avatar
No I do not plan on lowering the rear at all. I just wanted to make sure lowering the front when I did the 21 wasnt going to be messed up by adding the shocks that I did in the rear. Thanks for the replies and help.
Need help - need a tuner with some skills in SW Mich Captain America Dyno Results 1 06-03-2017 12:51 AM
need help figuring which bars I need ironmike666 Controls & Handlebars 14 01-06-2013 11:56 PM
Need help setting up my wife's Road Glide NCTim *General Road Glide Discussions/Pictures 5 11-09-2010 12:27 PM
Need help on winshield size RWB427 *General Road Glide Discussions/Pictures 12 06-28-2010 01:10 PM
Need your help HUTMO Windshields 9 03-20-2010 09:00 PM
