Rear drop brackets - quick question - Road Glide Forums
post #1 of 4 (permalink) Old 01-04-2012, 04:35 PM Thread Starter
Sethjamto's Avatar
A buddy gave me some lowering brackets and a set of his stock rear shocks. I'm currently running the stock 13"ers on my 08 RG. My plan is to send the spare shocks out to bitchinbaggers to have them cut down to size for me, all while still having my shocks on so I can continue to ride.
I want to temporarily install these rear drop brackets so that I can play around with the ride height. I'm doing this so that I know exactly how much I want the shocks cut down. I do not have a bike lift. Can I remove the stock shocks to install these drop brackets with the bike on the side stand? Or do I need access to a bike lift?
I was hoping for a quick 45 minute job sitting in the garage tonight so that I could give it a test ride to work tomorrow morning in a lowered state to feel her out!
Also, how low can I go with the blocks before I have a problem with rubbing the wiring on the inside of the fender that I've read about?
I know that shocks are the way to go, and that is my goal with this project. Remember, I am doing the blocks as they were given to me and I want to test different ride heights to see what I like the best. I only say this because I know that people with chime in with their negativity against lowering blocks. I DO agree with you. This is for testing purposes only so that I can send my spare shocks to bitchinbaggers to get cut down.
Thanks in advance!!
2015 Denim Black FLTRXS
14" Vindikta's - Rinehart True Duals - SE Heavy Breather Elite - Screaming Eagle Pro Super Tuner - King Tour Pak - 85.45hp / 104.41tq
Sethjamto is offline
post #2 of 4 (permalink) Old 01-04-2012, 05:20 PM Thread Starter
Sethjamto's Avatar
Found my answer. A bike lift is needed is what I found, which is what I figured the answer was.
post #3 of 4 (permalink) Old 01-04-2012, 08:07 PM
Let me guess, you took the shock bolts out without a jack and having a hard time picking up the bike to reinstall the bolts. I have the blocks and love them. Nothing wrong with the blocks that i can see or feel and ive been using them now for 20k miles. You will need at least a jack to get the rear suspension to move were ever you need it to be in order to get everything lined up. Its only about a 20min job with a jack
post #4 of 4 (permalink) Old 01-05-2012, 11:35 AM Thread Starter
Sethjamto's Avatar
Nope! I decided to ask FIRST!
If figured that would happen, that is why I asked....but found the answer. That is what I did NOT want happening!
I may take her to work tomorrow and GENTLY use the forklift to lift the rear a little...not sure if I like that idea though...
What setting are you running on your drop blocks? I definitely DON'T want to risk rubbing the wires inside the fender!
110 drop in, CVO w/Mods, 117 drop in Lou Dude Dyno Results 1 03-08-2017 08:59 AM
Rear lowering brackets pennstater Parts for Sale 2 02-22-2015 06:17 PM
Drop-in kit, is it really a drop in? Transporter Suspensions 10 01-29-2015 01:22 PM
Rear footrests and brackets uawman Parts for Sale 0 11-03-2013 11:40 AM
Pingel Rear Lowering Brackets Part#62140 METIME Sold 0 04-07-2013 09:21 PM
