Easier Sag Measurement - Road Glide Forums
post #1 of 4 (permalink) Old 04-21-2014, 01:05 PM Thread Starter
teejay's Avatar
I apologize if this is a repeat.
I use a nylon tie strap as a "tattletale" when setting shock preloads using the following procedure.
Fasten a tie strap around the shock absorber rod and trim the end well within the spring. Raise the bike to full shock extension and push the tie strap tight against the shock body. Lower the bike and apply whatever load you are preloading for.
Raise the bike to full extension again and measure distance between the tie strap and the shock body to obtain the sag measurement.
This method is easily repeatable and can be performed by one person. Additionally, the "tattletale" can be used to measure maximum suspension travel under actual road conditions as long as the shock is not bottomed during the test.
Again, sorry if this is a repeat.
tj
teejay is offline
post #2 of 4 (permalink) Old 04-21-2014, 01:37 PM
TRUBlue's Avatar
I use a nylon tie strap as a "tattletale" when setting shock preloads using the following procedure....
tj
I've used this method several times, it has been mentioned. Works good. Do be sure you don't bottom out if you ride test, if you do, you could risk messing up a seal and leaking shock oil; that ain't no fun for sure.
'12 FLTRU Big Blue Pearl
TRUBlue is offline
post #3 of 4 (permalink) Old 04-21-2014, 02:02 PM
Thanks for the tip.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #4 of 4 (permalink) Old 04-21-2014, 02:11 PM Thread Starter
teejay's Avatar
Sorry, bad search on my part.
tj
teejay is offline
I need to replace my cowbells . what is easier ? MarkL Suspensions 2 04-10-2017 08:58 PM
944 SAG - What's yours? rabell Suspensions 5 03-27-2014 03:53 PM
Easier way to install balancing beads dougm1950 Wheels and Tires 13 01-05-2014 03:23 PM
Tri-bar running light sag? Stalkker66 *General Road Glide Discussions/Pictures 7 09-30-2013 07:23 AM
Measurement for RGU stock windshield? ichiban Windshields 6 03-20-2011 05:20 PM
