What would going 1 inch lower on my front end do? - Road Glide Forums
post #1 of 9 (permalink) Old 04-24-2014, 03:44 PM Thread Starter
I am contemplating changing out the springs in my front forks on my 11 RGU. I am hoping to improve the ride / handling plus maybe get a little better footing.
Would going with 1 inch lower fork springs on an otherwise stock suspension hurt anything?
2011 Road Glide Ultra - Silver the fastest color!
S&S teardrop / 255s / Crusher true duals and mufflers / SEPST / Mean City modded seat / and on and on and on
Hawkeyestoob is offline
post #2 of 9 (permalink) Old 04-24-2014, 03:57 PM
If you're going 1" lower, I would seriously consider monotubes.
Sent from my SPH-L710
post #3 of 9 (permalink) Old 04-24-2014, 07:10 PM
ERod62's Avatar
Monotubes will improve handling, lower is up to you if need it for better reach or bigger wheel. The stock and lower set ride same. Use to have stock switched to 1 inch lower can't tell any different on performance.
Sent from Motorcycle.com App
ERod62 is offline
post #4 of 9 (permalink) Old 04-24-2014, 10:53 PM Thread Starter
Wouldn't some of the new springs also improve handling?
The improved reach will also be beneficial to me.
post #5 of 9 (permalink) Old 04-25-2014, 03:31 AM
Taccone's Avatar
the improved ride quality of the monotubes are what you are looking for. I have them installed in my bike, 1" lower, cooler look, much better ride, no front end brake dive, and for you it'll get you closer to the ground for added reach.
Taccone is offline
post #6 of 9 (permalink) Old 04-25-2014, 07:34 AM
DED HD's Avatar
i dont think you will get a better ride or handling by lower springs in the front on your ultra, but it will slightly help with better footing. i have hd lowering springs in my front for the last 4 years on my custom but just switched to progressive monotubes lowering cartridges. your rear end may be a little higher, and the monotubes lowered my front more than an inch(much lower than the lowering springs) using the suggested 3 clips for a one inch lower stance. i also have the cvo adjustable lower shocks on the rear.
im so much happier with the monotubes. no more brake dive. much tighter handling
'10 Red Custom:
DED HD is offline
post #7 of 9 (permalink) Old 04-25-2014, 10:40 AM
Monotubes my custom handles like it is on rails in conjunction with my Legend Revo shocks.Springs alone won't do it .
roadwolf is offline
post #8 of 9 (permalink) Old 04-25-2014, 01:21 PM Thread Starter
Thanks for the replies so far.
I am thinking I will go with the standard height monotubes. I have read that many people say it slightly lowers the front end. If that happens I will consider it a bonus.
You have all confirmed what I have been finding while reading countless treads about the monotubes. Increased comfort and much better feel from the front end when you are pushing it beyond a slow ride in the country. There is nothing worse than hitting the breaks or going into a turn where there are some bumps and having the front end feel like its going 20 different directions on you all at the same time.
post #9 of 9 (permalink) Old 04-25-2014, 03:05 PM
I run the stock height mono tubes. I did not take before and after measurements but consider lowering the front end to be for looks only. A lower front end will decrease cornering clearance and fork travel. Granted the mono tube will ride much better than stock. This is solely my opinion as most people here like to lower their front ends, but less travel means less ability to soak up bumps, does it not?
I lowered my softail and immediately noticed the lees travel although the different springs and Ricor intiminators made a difference next time I decided I would do stock height.
HogPro is offline
21 inch front end help me with my setup WFOFLTRXS Wheels and Tires 14 01-12-2018 02:22 PM
21 inch front/ 18 inch rear tire 02gray Wheels and Tires 6 05-29-2017 07:42 PM
What do I need to know when looking for an A/C? What would you run in my shoes? kyle31490 Intake and Exhaust 11 03-25-2014 10:03 AM
If I lower the rear do I have to lower the front?? StrokerAce Suspensions 13 11-17-2013 02:32 PM
Lower front end -2 or -1 with Monotubes manchu Suspensions 30 12-25-2012 05:30 PM
