Ride high Park low... Possible? - Road Glide Forums
post #1 of 6 (permalink) Old 01-17-2012, 11:51 PM Thread Starter
I've got a small dillema... I like long trips on the bike and need storage. So Sumax Wide Extended bags are in order. I ride hard so need some clearance so bags don't rub, yet I want to park w/o the kickstand. So in otherwords is it possible to get the bike riding high and park low.
timmcgraw67 is offline
post #2 of 6 (permalink) Old 01-18-2012, 05:44 PM
Xaran's Avatar
Air Ride system, you can drop it to the frame if you remove the bump stops. But there is a danger with doing that If you loose pressure while riding it will drop to the frame at speed. Also the handling may not be as good as a quality shock like Ohlins, Progressive or Works, Terrycable could provide.
Xaran
Previous HDs
2004 Road King Custom - SOLD
Xaran is offline
post #3 of 6 (permalink) Old 01-18-2012, 10:29 PM
Explain on how you can park a bike without a stand of some sort???
post #4 of 6 (permalink) Old 01-18-2012, 10:32 PM
ChromeYellow67's Avatar
Full on bagged air suspension can lower the bike all the way down.
Way to pricey for me, but possible.
2015 FLHR Morocco Gold Pearl
ChromeYellow67 is offline
post #5 of 6 (permalink) Old 01-19-2012, 01:05 PM
OK! I seen that before I didn't know what they called that system.
post #6 of 6 (permalink) Old 01-19-2012, 01:20 PM
laxinharley's Avatar
Air ride system is your best bet. Probably around 1500-2500 depending on the system. Although you may be able to drop it super low I imagine you would have to modify the frame to make it sit on the ground.
Or throw a 300 center stand on it.
laxinharley is offline
High Oil Pressure and High Oil Temps ironmark Troubleshooting for Road Glides 17 12-09-2012 10:44 AM
HID High Beam Low Beam Fit EasternSP Lighting 9 09-29-2012 01:05 AM
How high should high beam really be jacksonfdny Lighting 4 09-11-2012 06:37 AM
Took a nice ride today through Glacier Park Moonrunner Road Trip Discussions/Stories/Pictures 28 07-15-2012 09:18 PM
Crotch Rocket - Low/High controlled turns DreamRider Videos 6 03-01-2011 10:00 PM
