Monotube question.... - Road Glide Forums
post #1 of 8 (permalink) Old 01-19-2012, 09:26 AM Thread Starter
Nozzleman 216's Avatar
I have been reading and searching the net for over a day and I can't quite find what I am looking for. I want to get some things power coated over the winter and REALLY want to do my forks. With that said, next winters mod list will include a new wheel (probably 21) which will then require a suspension change (lowering).
So can I do the monotubes and lowering now then add the taller wheel later? What are my options here? I really want to tear the forks apart once and be done.
Any suggestions?
Thanks!
Captain, Coshocton Fire Dept.
IAFF Local 216 Secretary/Treasurer
2008 Mirage Orange Road Glide
Nozzleman 216 is offline
post #2 of 8 (permalink) Old 01-19-2012, 10:18 AM
1BigGuy's Avatar
Get the Monotube with the lowering componet. it has the option of 1 or 2 inch lowering. you can do it in stages or just do the 2 inch to begin with. go 1 inch now and 2 inches with the large wheel later. Either way on a RG it will ride fine with the current 18 inch wheel.
2010 FLTRX Black Denim
2007 FLSTN Vivid Black
1BigGuy is offline
post #3 of 8 (permalink) Old 01-19-2012, 10:25 AM Thread Starter
Thanks....but I believe my current wheel is not 18" (09 later?)
So can I get away with 2" now and not have to piss with it later? And if not how hard is it to change later!
post #4 of 8 (permalink) Old 01-19-2012, 11:35 AM
You have 16" wheels front and back on your bike. I would seem that lowering the front end 2" and using the 16" wheel and not lowering the back would affect the handling along with the ride.
post #5 of 8 (permalink) Old 01-19-2012, 11:41 AM Thread Starter
I just may lower the rear Looking at sending my rears to BitchinBaggers for now then an upgrade later
post #6 of 8 (permalink) Old 01-19-2012, 11:55 AM
skratch's Avatar
i can't say whether or not to lower, but just for reference purposes, your 16 inch wheel/tire combo has the same overall diameter as the 17, 18 or cvo 19.....
skratch is online now
post #7 of 8 (permalink) Old 01-19-2012, 01:41 PM
If you lower your rear 2", problem solved automatically. Check with bithching baggers, I believe if you lower the rear 1-1/2" you should be able to lower the front 2", the rear affects the bike more than the front when being lowered.
post #8 of 8 (permalink) Old 01-19-2012, 03:59 PM
homeboy58's Avatar
I have the monotubes up front at -2" and the 940s in the rear, which lower the rear 1" from stock. it sits pretty level. I also plan on doing the 21" front this summer. I'm not sure if if I will have to change the front with the larger wheel...
2010 FLTRX | Stage 1 |SE tuned |84.07 HP | 95.28TQ | Progressive 940's -1 | Progressive monotubes-2 | Performance Machine l Clearview | Cyclesmiths | Klockwerks | Hells Foundry | MCC | Corbin | J&M | Yafee| Ness | RSD l Covingtons l CustomDynamics | Garmin | Badlands |LePera | TopShop,...to be continued
homeboy58 is offline
Monotube after purchase lowering question pasa Suspensions 7 06-24-2013 11:16 AM
Progressive Monotube Question NORSEMAN Suspensions 10 02-21-2013 09:18 PM
Another Monotube question Sparkles Suspensions 29 02-01-2013 05:28 PM
Progressive Monotube Question Willy_B Suspensions 35 12-15-2012 10:43 PM
Progressive lowered Monotube question easyrider9809 Suspensions 11 05-23-2012 12:00 AM
