Progessive Monotube Clunk - Road Glide Forums
post #1 of 9 (permalink) Old 05-03-2014, 11:14 PM Thread Starter
watsondog's Avatar
Sorry folks..
Cant seem to find the thread where a fellow member after a monotube install was having a clunking issue..hoping you might be able to point me in the right direction....
I did the -2 drop no spacers just the 2 springs in each side...but sounds like a clunk when the front end rises or falls during a bump maybe a neck bearing adjustment? or just lose as he77?
thanks for your help
Watsondog
"Let me know how that works out for you"
2011 103" RGC
Reinhart Extreme Duals
S.E. Street Tuner
21" Colorado Custom Slammer 5
Mean City heated seat
Yafee 10" bars
Cams & Dyno soon to come
watsondog is offline
post #2 of 9 (permalink) Old 05-04-2014, 12:01 AM
Shark daddy's Avatar
Mine has a little clunk too. Took it apart and could not find any problem. Had the dealer look at it and they could not help with any advice. They checked the neck and all good. I have learned to live with it and after about 17,000 miles have not gotten any worse. No wobble, drives great. I also called Progressive a couple of years ago and they were no help. I have installed the monotubes on two friends bikes and they don't clunk. Sorry, don't have a cause or cure.
"Don't Cheat yourself, Treat yourself"
2015 Superior Blue RG Special
Shark daddy is offline
post #3 of 9 (permalink) Old 05-04-2014, 12:52 AM
JJSW1283's Avatar
+3. Lowered 2" with the clunk.
JJSW1283 is offline
post #4 of 9 (permalink) Old 05-04-2014, 01:13 AM
Q-Hog's Avatar
No clunk for me.. 2" drop..
Q-Hog is offline
post #5 of 9 (permalink) Old 05-04-2014, 01:22 AM
Taccone's Avatar
Is it every time you hit a bump? Could it possibly be the brake lines tapping on something with all that extra slack they now have? I'm lowered 1" and hear a clunk/tap noise when I hit my front brakes for the first time pulling the bike out of the garage
Taccone is offline
post #6 of 9 (permalink) Old 05-04-2014, 12:09 PM Thread Starter
watsondog's Avatar
It really only occurs on decent size bumps at slow speeds...thanks for the heads up on the cables I will ck that...I'm going to ck my neck bolt torque and if that good I'm going to deep dive and adjust swing if need be.
2011 103" RGC
S.E. Street Tuner
Yafee 10" bars
post #7 of 9 (permalink) Old 05-05-2014, 05:59 AM
JsGlide's Avatar
You have to install the spacers that come with the mono tubes. Mine did the same thing I had to take them apart and put the spacers in. After that its been fine.
JsGlide is offline
post #8 of 9 (permalink) Old 05-06-2014, 08:49 PM Thread Starter
watsondog's Avatar
2011 103" RGC
S.E. Street Tuner
Yafee 10" bars
post #9 of 9 (permalink) Old 05-06-2014, 08:53 PM Thread Starter
watsondog's Avatar
2011 103" RGC
S.E. Street Tuner
Yafee 10" bars
Monotube clunk rlaf75 Suspensions 9 10-10-2017 12:04 PM
monotube clunk? SIG556 Suspensions 3 05-04-2013 09:53 PM
Who's installed Progessive Drop-In Springs on their RG? jdbaker Suspensions 17 07-21-2012 09:49 AM
Clunk Sancho Troubleshooting for Road Glides 27 07-17-2012 08:33 AM
What pre-load are you running on your Progessive 940 Ultra Touring? jdbaker Suspensions 10 05-03-2012 10:39 PM
