How many seconds to dump Gabriel shocks - Road Glide Forums
post #1 of 5 (permalink) Old 05-05-2014, 06:40 AM Thread Starter
adown's Avatar
Hi everyone, I am going to go with the Gabriel Air Shock mod, so I designed an electronic control unit to dump the air when I turn off the ignition. I need to know how many seconds it actually takes to dump the air from full to empty. I could guess, but I don't want to power the solenoid longer than necessary. It has adjustment of a couple seconds either way, but I need a starting point. Thanks, adown
adown is offline
post #2 of 5 (permalink) Old 05-05-2014, 08:45 AM
McLuvin's Avatar
Mine is between 7 and 11 seconds I would think. If I ride tonight I will count it off when I dump it. I have a small solenoid valve located in the faring. If yours is mounted at the shocks it may dump faster or if you have a 1/4" line and valve. Most people like this because of the adjustability. Can you manually inflate and deflate or will it always be done by the controller?
excuse me while I whip this out...
McLuvin is offline
post #3 of 5 (permalink) Old 05-06-2014, 06:44 AM Thread Starter
adown's Avatar
I will be able to manually inflate and deflate. For the most part the inflate will be handled by a programable pressure switch, and the deflate by the key off timer. Once I find the sweet spot for single and 2 up, it should be a hands off system. It's a RGU, and I don't need more buttons to mess with. I am even contemplating putting a pressure switch in the passenger seat so it can auto select the air shock pressure. I have calculated the solenoid control circuit at 15 seconds, so it sounds like I'm pretty close. Thanks for your help.
adown is offline
post #4 of 5 (permalink) Old 05-06-2014, 08:40 AM
McLuvin's Avatar
Sounds like a cool idea. It will freak people out if you pull up and get off the bike and then have it lower itself. Best of luck getting it dialed in.
McLuvin
McLuvin is offline
post #5 of 5 (permalink) Old 05-06-2014, 09:13 AM
Maybe 3-4 seconds. Not vary long. Now to air up, that take longer unles you have a tank. Sounds cool. Post a vid when you get it done.
Toby
twistedcherokee is offline
Sound cuts off for a few seconds Adam87t2 Audio 8 10-10-2015 06:53 PM
Seconds Face On OneSlickGlide Clothing 14 01-01-2015 10:15 AM
FS: Gabriel Air Suspension set up (NEW) DewmanCO Sold 11 02-22-2014 03:39 PM
gabriel, oh, where for art thou gabriel? h-donut Suspensions 7 06-02-2012 11:37 PM
