2,500 miles - pulled lower fork sliders, should i install new seals/bushings? - Road Glide Forums
post #1 of 9 (permalink) Old 01-25-2012, 12:44 PM Thread Starter
hi all,
just pulled my lowers off to powder coat and was wondering if the seal/bushings of the front shocks need to be replaced? i visually inspected them and they look fine. the bike is a 2012 and only has 2,500 miles on it. i just wasn't sure if these parts were like the derby cover seals you need to replace every time you take the cover off. any help would be most appreciated
cheers,
matt
"at the end of the game both the king and the pawn go back into the same box"
modot66 is offline
post #2 of 9 (permalink) Old 01-25-2012, 01:17 PM
I would just to be sure. it is a fair amount of work to pull replace them again if they do loeak. It only takes the slightest knick to have leaky forks. I am guessing you pulled them out before powder coating so there is that chance they leak and just not worth the work. If it was like a derby cover it isno big deal to replace if they leak but forks are a pain to pull off again
jeff is offline
post #3 of 9 (permalink) Old 01-25-2012, 01:27 PM
Redfish-Joe's Avatar
You are over halfway there already. Spend the few bucks for the seals and Don't worry about them for a long while.
Redfish-Joe is offline
post #4 of 9 (permalink) Old 01-25-2012, 04:30 PM
fltrx103's Avatar
+2 Go ahead and replace the fork seals while you have already done the hard part and have the bike all torn down.....Oh and by the way... the derby cover gasket is good for many times use....just check it for tears and re-use it if its OK....H-D recomends the new gasket each time to sell you a new one
2011 FLTRX103..Vivid Black, Mirror chrome Agitator wheels 19/18, Jackpot 2-1-2 head pipe, S/E A/C, Klock Werks S/S shorty slip-on mufflers, Mustang seat 10"WV shield, H-D vented lower fairings.
fltrx103 is offline
post #5 of 9 (permalink) Old 01-26-2012, 12:52 AM
Xaran's Avatar
If you already have them apart think about installing progressive monotubes
Xaran
Previous HDs
2004 Road King Custom - SOLD
Xaran is offline
post #6 of 9 (permalink) Old 01-26-2012, 12:32 PM Thread Starter
Thanks Gents for the replies, I will replace the seals and bushings. Gonna also add some SE fork oil to get a bit stiffer ride. The Progressive Monotube seems awesome, but after all this powdercoating I'm gonna need to save up for a bit more!
modot66 is offline
post #7 of 9 (permalink) Old 02-23-2012, 10:45 PM
Good call on replacing both the seals and the bushings....for such cheap parts you would kick yourself if they leaked after reinstalling everything.
Cheers,
Trent
Dfwhockey17 is offline
post #8 of 9 (permalink) Old 02-23-2012, 11:26 PM
tmd
Every time I have taken apart a set of forks I leave the seal on the fork tube and reinstall it. I've done this at least 6 or 8 times installing chromed lowers on friends bikes and dozens of times on dirt bike forks in my younger days. In all those times I have never had a seal leak doing it this way. Also the bushing should be good for 50,000 plus miles so there is no need replace them either. The only thing that needs replacing is the fork oil.
tmd is offline
post #9 of 9 (permalink) Old 02-23-2012, 11:33 PM
50k on bushings? how many miles on the oil?
‘03 RG Fork Seals dbikers Suspensions 2 07-22-2018 02:36 PM
Lower fork tubes & sliders waco Parts for Sale 1 10-01-2015 09:33 AM
Black lower fork sliders Bigfoots03hd Parts for Sale 16 07-01-2014 06:55 AM
WTB: Lower Fork sliders 93-331-29psi Wanted! (Buy or Trade) 32 03-18-2013 09:45 PM
Question about fork seals Sealdoggy Suspensions 3 04-21-2012 12:44 AM
