Lowering Kits - Road Glide Forums
post #1 of 11 (permalink) Old 01-27-2012, 08:42 PM Thread Starter
MasterGunz's Avatar
Lowering Kits
Anyone install a lowering kit on their Road Glide? I have a 2009 FLTR and would like to achieve the ride height of an FLTRX at a reasonable price.
MasterGunz is offline
post #2 of 11 (permalink) Old 01-27-2012, 08:48 PM
I use a set of lowering blocks which lower the rear an inch. Cost me about $90. Very easy to do with a m/c jack. It will change the shock angle a lil bit but ive had them on for about 20k miles and havent noticed any difference. The front though is stock height.
post #3 of 11 (permalink) Old 01-27-2012, 08:48 PM
I bought a set off e-bay 17.90 delivered lowers 1-3 inches works good for me
Mike
thekidd is offline
post #4 of 11 (permalink) Old 01-27-2012, 08:50 PM
faststan's Avatar
I installed a Burley Slammer kit (10.5 rear shocks and drop for front) on my RGU and it felt like a hardtail. Try the FLTRX 12" shock as a start. Plenty of used ones around to try.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #5 of 11 (permalink) Old 01-27-2012, 08:51 PM Thread Starter
MasterGunz's Avatar
Thanks for the input. I've had my eye a set of LA Choppers lowering blocks. I didn't think to look on e-bay. I'll try that a try.
post #6 of 11 (permalink) Old 01-27-2012, 08:53 PM
klyons8963's Avatar
Lowering
On my 2012 RGU I put the one inch shorter H/D shocks in the back and the progressive drop ins in the front that lowered it about 1.25". It has a much better ride and not spongy like stock. It stopped the nose dive on hard braking. The only drawback is adjusting the rear shock from 20 psi. to 40 or 45 psi. when riding two up or with a heavy load. This shifted some of the weight forward and made it more comfortable for me to ride because I am short guy with a 30" inseam.
2012 RGU Vivid Black
Vance and Hines Dresser Duals
Hi output mufflers
Heritage Bars
Progressive Mono-tubes
1" shorter rear shocks
klyons8963 is offline
post #7 of 11 (permalink) Old 01-27-2012, 08:56 PM Thread Starter
MasterGunz's Avatar
I was considering installing the Burley Slammer it on my Street Bob before I sold it.
I had also considered that option as well.
post #8 of 11 (permalink) Old 03-29-2012, 10:20 PM
Paul's Road Glide's Avatar
Mike
I've seen these and am considering it. Do you ride two up? I weight about 175 and my wife 100 even. Do you think dropping 2" will make me bottom out on the fender?
Paul's Road Glide is offline
post #9 of 11 (permalink) Old 03-29-2012, 10:43 PM
CHAINSAW's Avatar
Moved to the correct subforum
Such is the rule of honor.
CHAINSAW is offline
post #10 of 11 (permalink) Old 03-30-2012, 11:40 AM
Try the 12" FLTRX shocks. IMO, the lowering blocks change the angle & shocks don't work correctly!!!!
2011 FLTRX 103 Sedona Orange
Hillglide is offline
Looking for a little feedback on lowering kits Major99 Suspensions 9 12-04-2014 10:37 AM
lowering kits? Sedona Blue Suspensions 10 05-02-2014 04:16 PM
Burly lowering kits. Voodoo Suspensions 5 08-15-2012 02:51 AM
lowering kits???? 3FEETUNDER Aftermarket Accessories 28 01-07-2011 08:00 PM
