progressive monotube and 444 rear - Road Glide Forums
post #1 of 8 (permalink) Old 06-06-2014, 05:48 AM Thread Starter
waynemags's Avatar
hey all. I have a 12 roadglide. did the progressive 444 11inch in rear and the monotube kit up front lowered 1 inch. im 160lbs and just finished a 7000km road trip. not real happy with the front suspension. some bumps like when u come across a bridge deck or a good dip in the road. feels and sounds like the front end bottoms out. same for the rear setup. had the rear 2 1/2 turns in and same thing. feels like bottoms out. no rub marks anywhere on fender but definitely rough ride. anyone have this setup and noticed this? this was carrying about an extra 60 lbs on the back with my bag and tour pak with some stuff in it. as soon as o got home I switched my rears back over to progressive tail dragger 13inch air shocks. I don't want to dig back into the front end yet.
waynemags is offline
post #2 of 8 (permalink) Old 06-06-2014, 09:09 AM
SmokeyJoe's Avatar
Cant say I blame you on redoing the front. I have the standard hieght monotubes and left the c clips out. This dropped the front about 1" or more, but rides pretty good. I have the 944 in the rear and they sucked at first but now with just over a 100miles on them they feel better.
SmokeyJoe is offline
post #3 of 8 (permalink) Old 06-06-2014, 10:04 AM
mjsdouble's Avatar
OP... I have a the Monotubes -2 and 444 11.5". I'm running on 21/17 wheels. For me the Monotubes was a stiffer ride up front than the OEM set up. That's not to say it's not better. It took some getting use to but it handles so much better than before. The RR tracks and bumps are not nearly as teeth rattling as the stock set up was. The smaller bumps are not even noticed. The front end dive is no longer an issue. The 444's are a smoother ride as well. I weigh 180# and the shocks are set with 2 lines showing. I will need to play around with the setting when I carry a load. My ride is by far better than it was.
mjsdouble is offline
post #4 of 8 (permalink) Old 06-06-2014, 10:37 AM
Lowering the bike takes away suspension travel which will affect ride comfort. You will have to adjust to the change in your ride if you want a lowered bike.
post #5 of 8 (permalink) Old 06-08-2014, 01:30 AM
RichieRich's Avatar
What did you do with the 444s? Maybe I'll get tired of my air ride one day.
Sent from Motorcycle.com App
2013 BBP FLTRX
RichieRich is offline
post #6 of 8 (permalink) Old 06-08-2014, 01:56 AM
pipe3214's Avatar
I'm interested in the 944's :-)
pipe3214 is offline
post #7 of 8 (permalink) Old 06-08-2014, 10:35 AM Thread Starter
waynemags's Avatar
I stil have them put them on shelf. if your interested let me know. our roads around here are pretty rough so I prob wont run em
post #8 of 8 (permalink) Old 06-12-2014, 08:41 PM
Bigfoots03hd's Avatar
I thought the shortest 444s where 11.5 according to progressive website. I didn't realize they make a 11 inch shock for the touring bikes
Bigfoots03hd is offline
Progressive 444-4020B 13" FST HD shocks TRUBlue Parts for Sale 19 10-14-2013 10:32 AM
Progressive 444's OneSlickGlide Suspensions 33 08-23-2013 10:25 PM
Progressive 444's easyrider9809 Suspensions 1 01-07-2013 11:01 AM
progressive 444 hognit Suspensions 14 09-26-2012 12:27 PM
Progressive 444 basaltine Suspensions 1 07-28-2012 10:50 AM
