lowering your RG - Road Glide Forums
post #1 of 17 (permalink) Old 02-16-2012, 10:55 PM Thread Starter
Evolutionscc's Avatar
lowering your RG
OK, so I am thinking about lowering my 08'. What are your thoughts? Who has done this and how did it affect the ride? I ride 2-up about 30% of the time. I was thinking a 2" drop.
Evolutionscc is offline
post #2 of 17 (permalink) Old 02-16-2012, 11:21 PM
The biggest thing IMO would be clearance between the fender and tire. Dont know how much you or your passenger weigh but that should be taken into consideration. I went with a set of 1" lowering blocks for about $80 cuz its cheaper than shorter shocks. I believe there are blocks out there that will lower it more but the shock angle is going to be greater. The shock angle with the blocks i used was changed a lil bit but i never really noticed a ride difference. Ive had them on the bike for about 20k miles without any issues at all and im 300lbs and the gf is about 118lbs. I never did anything to the front and dont intend to at this time.
post #3 of 17 (permalink) Old 02-17-2012, 07:11 AM
Sethjamto's Avatar
I dropped the rear of my 08 with blocks 1.5" a coiple weeks ago. I used blocks to test different ride heights as I plan on having BitchinBaggers cut my shocks down eventually. This way I know exactly how low I want. I scrap floorboards all the time now and the kickstand too. Doesn't bother me at all...actually makes me smile every time I hear the sound! Be careful too of the rear tire rubbing the top inside of the fender. I've heard from some people that sometimes it will contact the wiring for the rear lights and rip the wires apart. I havent had this happen....but just be aware.
Have fun and send pics once you do it!
2015 Denim Black FLTRXS
14" Vindikta's - Rinehart True Duals - SE Heavy Breather Elite - Screaming Eagle Pro Super Tuner - King Tour Pak - 85.45hp / 104.41tq
Sethjamto is offline
post #4 of 17 (permalink) Old 02-17-2012, 08:15 AM
KrashKatz's Avatar
I had my Heritage lowered 2", looked cool, but got uncomfortable on longer rides. I scrape my kickstand and floorboards a lot on my RG, which is still at stock height. I'm 5'8, and have no issues reaching the ground.
If it's upside down and burning, you've gone too fast.
KrashKatz is offline
post #5 of 17 (permalink) Old 02-17-2012, 09:00 AM
Having lowered my previous bagger(a '92 FLHS), I will never do it again. They already have precious little suspension travel, and no matter what people say or percieve, it pretty much has to compromise the ride. If the shocks/forks are shorter, there's only one way to keep from bottoming out.....stiffer springs/harsher ride. Espescially if you ride two up, and/or ride agressively at times(I do both). If you just like the lower look, and who doesn't, be aware there is no free lunch. If you need to sit lower to the ground to be more flat footed, maybe consider the various seats that are cut lower? Just my opinion.
Jeff
akjeff is offline
post #6 of 17 (permalink) Old 02-17-2012, 09:16 AM
JayKS's Avatar
Jeff
Well said, Jeff. I agree 100%.
JayKS is offline
post #7 of 17 (permalink) Old 02-17-2012, 09:36 AM
Swagzilla's Avatar
I just sent my shocks to Ron @ bitchin baggers yesterday. I've never been a fan of lowering blocks they have always scared me. I am 5'6 bout 190, my wife is about 100 lbs. She's very seldomly rides so I chose to go with the 2 inch drop. I thought about only cutting the seat down but figured it wouldn't give me as much as I need considering I'm going with the 23x18 set up and I wasn't exactly flat-footed with the stock set up in the first place.
If bitchin baggers is the route you want to go, I suggest calling Ron. He's super helpful and knowledgeable and he won't try to sale something you don't need or won't like
07 Glide with a few goodies
People only hate when they are Jealous or Worried. So embrace your haters because they are just letting you know your doing something RIGHT!
Swagzilla is offline
post #8 of 17 (permalink) Old 02-17-2012, 10:57 AM
Wanted to add that IMO, if one is dead set on lowering their scoot, that for the rear end, using the highest quality possible, shorter rear shocks, would be the way to go. As opposed to kicking the shocks back with blocks. I suspect that the engineers at the MoCo, most likely have the shocks at the angle they are at, for a good reason. And for the front, use either cartridge inserts, or a damper tube modified with a Gold Valve style emulator, to get rid of as much dive as possible, and preserve what little travel is left in your forks.
Jeff
akjeff is offline
post #9 of 17 (permalink) Old 02-17-2012, 11:04 AM
I went with shorter shocks also, in order not to worry about wheel rub, my rear shocks are 11-1/2 inch and I have the progressive monotube -2" up front, solo I never have a problem which is how I ride 99% of the time, if I ride somebody over 150lbs, it tends to bottom on big bumps, but nothing extreme, BTW I'm 5'8" and 200lbs.
post #10 of 17 (permalink) Old 02-17-2012, 11:29 PM
WHY Ruin a good thing.
Is your RG your daily driver? dinggus *General Road Glide Discussions/Pictures 52 01-10-2018 02:29 PM
hd lowering Cartridge Fork Kit or progressive lowering kit IranAround Suspensions 11 03-21-2015 01:09 PM
Post pictures of your RG at your favourite Bar-Restaurants DreamRider Road Trip Discussions/Stories/Pictures 34 07-30-2012 04:48 PM
lowering the 2012 rg custom dbrews1954 Road Glide Specific Discussions 6 09-29-2011 02:35 AM
Lowering a 2007 RG TINMAN1 Suspensions 0 07-23-2011 07:47 PM
