lowering spring installation question - Road Glide Forums
post #1 of 3 (permalink) Old 02-18-2012, 05:12 PM Thread Starter
I pulled my forks apart today to get the lower legs powder coated and to install my lowering kit. When I pulled the forks apart the way all of the components were installed did not match from side to side. The little valve thingy with the little spring that goes between the dampener rod and the spring was installed with the spring up on one of the forks and down on the other. Which way is correct?
junk runner jr is offline
post #2 of 3 (permalink) Old 02-18-2012, 05:29 PM
JayKS's Avatar
Looks like someone's been in those forks before. What you're describing sounds like Gold Valve Emulators. Do they look like this?: http://racetech.com/page/title/H-D%2...mulator%20Kits
If that's what you've got, they should be installed spring side up.
JayKS is offline
post #3 of 3 (permalink) Old 02-18-2012, 09:42 PM Thread Starter
It looks very similar but its not gold and i cant see where they are adjustable. To be quite honest it looks like a factory piece rather than aftermarket. Thanks for the heads up on that though. I will go ahead and install them spring up.
hd lowering Cartridge Fork Kit or progressive lowering kit IranAround Suspensions 11 03-21-2015 01:09 PM
Fairing amp installation question SharkBite Do-IT-Yourself 2 03-27-2013 03:37 AM
Yet ANOTHER Tour Pack installation question d-roadglidr Lighting 5 11-28-2012 05:32 PM
RF amp installation question rustyj671 Audio 21 11-09-2012 02:23 AM
Intercom installation question DRAFT1 Equipment-RG 1 06-22-2011 07:56 PM
