Arnott adjustments - Road Glide Forums
post #1 of 2 (permalink) Old 07-02-2014, 07:14 AM Thread Starter
SmokeyJoe's Avatar
Arnott adjustments
So I recently installed the top of the line arnott system. I am having a difficult time understanding the adjustment strategy, could someone please explain this to me or maybe I am over analyzing this.
I am a light weight (165lbs). I pumped it up to 45lbs, the height seems to jump from slammed to full height around 35-40lbs. Should I be aiming for somewhere in the middle of the shock adjustment range? What's the minimum air pressure I can ride on? Any idea where to set the adjustable thumb screw for dampening?
I can't believe these question are not answered on their site.
SmokeyJoe is offline
post #2 of 2 (permalink) Old 07-02-2014, 10:20 AM
faststan's Avatar
A quote from Arnott to me "you will never use more than 2 clicks on the thumb adjustment". They adapted a set of shocks to fit their marketing scheme. I have never changed my thumb adjustment since putting the shocks on 3 years ago.
As Tracey says, air it up all the way then bump the discharge button twice to release some air. The psi gauge is subjective. Mine changes whether I have my tour pak on or not. Once I get enough air into the shocks to start raising the bike the psi gauge stays at the same reading.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
New Madstad / recommended adjustments TRUBlue Windshields 4 03-11-2014 10:07 AM
Helmet Adjustments? HOGDAT General Off-Topic Discussions 15 01-08-2014 07:54 PM
Neck Bearings and adjustments cajunglide *General Road Glide Discussions/Pictures 1 12-12-2013 05:46 PM
Cable Adjustments Nordic13 Controls & Handlebars 4 04-27-2013 10:25 PM
250 watt amp adjustments craigv65 J&M 4 05-05-2012 10:39 AM
