Monotube 31-2500 with no preload clips? - Road Glide Forums
post #1 of 10 (permalink) Old 07-07-2014, 07:13 PM Thread Starter
Anyone running the stock height monotube kit with no clips?
This is what Progressive suggested to me for about 1/2" lower stance...
How do they perform this way? Ride weight a big factor, I presume?
Thanks, guys!
V-man is offline
post #2 of 10 (permalink) Old 07-07-2014, 07:16 PM
I use one clip per side. Firm but still gives a little softness on bumps. You should be even softer with no clips.
post #3 of 10 (permalink) Old 07-07-2014, 08:47 PM
HellInABucket's Avatar
All depends on your weight.
I'm 175, running one clip, rides *great*
HellInABucket is offline
post #4 of 10 (permalink) Old 07-08-2014, 02:09 PM
SmokeyJoe's Avatar
Mine is setup this way, I am 165lbs. I don't like it much, if I could tear it apart I would. Then I would put one clip in. I think I had at least 1" drop, as you can see by my yaffe burner sliders.
SmokeyJoe is offline
post #5 of 10 (permalink) Old 07-08-2014, 02:14 PM
SmokeyJoe's Avatar
Another view, you can see how low the slider is on the fork. Normally the cuts in the fork would be much lower with some black showing I between. If that makes any sense.
post #6 of 10 (permalink) Old 07-09-2014, 12:18 PM Thread Starter
SmokeyJoe; That is the lowered monotube kit on Your bike, 31-2501?
V-man is offline
post #7 of 10 (permalink) Old 07-09-2014, 12:39 PM
SmokeyJoe's Avatar
Nope that is the standard height monotube without any c clips
post #8 of 10 (permalink) Old 07-09-2014, 12:46 PM Thread Starter
And that lowered it an inch... Wow. Now I'm really confused!
Seems like I'm not getting the right info from Progressive maybe...
V-man is offline
post #9 of 10 (permalink) Old 07-09-2014, 01:56 PM
SmokeyJoe's Avatar
Yeah that's how I felt after my install. I would go with one clip
post #10 of 10 (permalink) Old 07-10-2014, 12:29 PM
Tinsleytown's Avatar
I'm running the stock height mono tube with no preload clips on a 23" front wheel. I'm running travel limiters to prevent hitting the fender but I rarely hit the stops and I'm 265 lbs. I called Progressive and told them my set up and my weight and they said no preload clips. They also said it would sit a 1/2" lower but its pretty close to what my ride height was with stock springs.
2013 Road Glide Custom. 23" PM Revel Front/17" PM Revel Rear. Bad Dad Wrap Front Fender. PM Contrast Cut Fork Legs. Yaffe 10" OEM Monkey Bars. Daymaker LED Headlamp. RSD Turbine AC. Vance & Hines Dresser Duals with CFR Fluted Tip Slip-ons. RSD Boss Seat
Tinsleytown is offline
Monotube 31-4001 1" lowered on a 2015 RGS NETacoma98422 *General Road Glide Discussions/Pictures 15 05-22-2016 01:13 PM
Progressive Suspension Monotube Fork Lowering Kit part number 31-2501 daryl_db Parts for Sale 4 03-11-2015 11:22 PM
WTB monotube preload clips rlaf75 Wanted! (Buy or Trade) 2 03-11-2015 08:16 AM
31-2500 on Amazon 236.63 93-331-29psi Suspensions 11 08-02-2014 11:19 PM
progressive monotube preload spacers ehorn133 Suspensions 7 07-23-2012 12:57 PM
