Monotubes or dropin springs - Road Glide Forums
post #1 of 9 (permalink) Old 03-05-2012, 10:09 PM Thread Starter
I'm trying to decide which lowering kit is better. A Monotube or Spring dropin kit for a 21in front wheel. Only want to lower a inch. I got a 2012 road glide.
Koda1975 is offline
post #2 of 9 (permalink) Old 03-06-2012, 08:18 AM
HD_Shock's Avatar
Pros and cons man ...
The drop in spring kit is cheaper and easier to install. The monotube kit is more expensive and a complete fork teardown since you're replacing everything. Either one will be an improvement but I'd go for the monotube if you can swing it ... it's just better technology.
-phil
2011 FLTRX 103
HD_Shock is offline
post #3 of 9 (permalink) Old 03-06-2012, 10:06 PM Thread Starter
Thank you for the reply.
Koda1975 is offline
post #4 of 9 (permalink) Old 03-07-2012, 01:32 PM
Xaran's Avatar
+1 on the Monotubes, they are a big improvement over the stock forks, your best choice.
If you cant do the Monotubes IMO go with the traditional lowering kit (that uses a short spacer spring under the damper to shorten the extended length of the fork) Im not a fan of the Drop In Lowering Kit, they seem to make the forks a little soggy for my taste. If you look at the way they work they just allow a controlled amount of sag in the forks and its not possible to preload the springs for rebound because the preload (spacer0 is what allows them to sag and lower the bike. if you use the old style lowering kits you can properly preload the springs for your weight.
Xaran
Previous HDs
2004 Road King Custom - SOLD
Xaran is offline
post #5 of 9 (permalink) Old 03-07-2012, 04:15 PM
Shark of the Quarter Apr-Jun13
I have a 21 inch wheel and have decided to go with the monotubes for the one inch drop as well. I am excited and looking forward to getting the work done...
2012 RG Custom CVO "Skunk" Construction Complete
Cmathias is offline
post #6 of 9 (permalink) Old 03-07-2012, 05:06 PM
1BigGuy's Avatar
I had both on various bikes. Go with the monotube, its better tech and makes the front end a little more responsive.
2010 FLTRX Black Denim
2007 FLSTN Vivid Black
1BigGuy is offline
post #7 of 9 (permalink) Old 03-07-2012, 10:30 PM
If you drop in a set of Progressive springs you also want Race Tech gold valve cartridge emulators which would be a great set up for easy installation. For roughly the same price you can get the Progressive Monotube cartridge. I just ordered my Monotubes.
Fog Shark is offline
post #8 of 9 (permalink) Old 03-07-2012, 10:37 PM
Go with the monotubes, you will be happy, I went with the 2" drop myself.
post #9 of 9 (permalink) Old 03-08-2012, 12:49 AM
Wharf Rat's Avatar
I'm happy with the monotubes, though I didn't lower mine. Eastern Performance, $266 delivered.
Like I told you. What I said. Steal your face right off your head.
Wharf Rat is offline
Hot Springs, Pig Trail, Eureka Springs weekend ride throttles&triggers Road Trip Discussions/Stories/Pictures 2 09-08-2014 09:49 PM
Hot Springs anybody lowdog Road Trip Discussions/Stories/Pictures 10 08-22-2011 04:13 PM
Hot Springs Rally sep 8-9-10 jimmyray11349 Organize Rides Here 1 08-21-2011 12:39 AM
Last springs out west trip DRAFT1 Videos 6 01-26-2010 07:30 PM
