Ohlins 3 -3 adjustment help? - Road Glide Forums
post #1 of 8 (permalink) Old 03-09-2012, 12:55 PM Thread Starter
VividRGU's Avatar
I have my Ohlins installed on my RGU but I'm unable to get a hold of Howard at Motorcycle Metal, it seems his phone is out. Could someone who has these shocks installed explain how Howard had you adjust the shocks initially, and then after the 500mile and 1,000mile (i think) mileage mark?
Thanks in advance!
VividRGU is offline
post #2 of 8 (permalink) Old 03-09-2012, 09:49 PM
swede0030's Avatar
Subscribed!
Jim
09 CVO rear, Ricor intiminators, Ohlins 3-3, Blade wheels, Corbin Solo, KW 1 1/4" heritage bars, Zumo 665, Chopped TP,255se cams, Bub 7's, Touring Duals, PCV
2011 RGU
swede0030 is offline
post #3 of 8 (permalink) Old 03-10-2012, 11:50 AM
tj316's Avatar
which number are you calling ????? he has a new number 954-848-1525 , with that said I believe he is at Daytona today in the pits tuning suspension for some of the race teams
tj316 is offline
post #4 of 8 (permalink) Old 03-10-2012, 02:07 PM Thread Starter
VividRGU's Avatar
Yep, I had the wrong number. I'm still interested to know if anyone has adjusted the spring hight after 500 miles or with a full touring load and passenger?
VividRGU is offline
post #5 of 8 (permalink) Old 03-10-2012, 02:28 PM
tj316's Avatar
I adjusted my sag when I got them to 1/3 stroke like Howard recommends , after riding they did soften up , after about 750 miles I reset my sag , I played with the adjuster at the bottom of the shock to find the spot that felt best to me , all this was set for me riding solo , my wife is 125lbs , when we ride 2up I do not change the sag but turn the adjuster 2 clicks stiffer and this works fine for me , 2up fully loaded depending on the weight I usually go 1-2 complete turns stiffer on the sag setting
tj316 is offline
post #6 of 8 (permalink) Old 03-11-2012, 02:38 PM Thread Starter
VividRGU's Avatar
Thanks TJ, by 2 complete turns are you referring to adjusting the spring ?
Thanks again!
VividRGU is offline
post #7 of 8 (permalink) Old 03-11-2012, 03:10 PM
tj316's Avatar
Thanks again!
yes , the spring
tj316 is offline
post #8 of 8 (permalink) Old 03-11-2012, 07:24 PM Thread Starter
VividRGU's Avatar
Thumbs up
Excellent, thanks for the input.
VividRGU is offline
Ohlins HD 357 vs Ohlins HD 022 mach65 Suspensions 8 09-08-2015 11:54 PM
HELP REQUIRED to get Ohlins 13" Groak Suspensions 6 06-29-2015 01:08 AM
Help with my Ohlins Nails Suspensions 2 07-04-2014 01:07 AM
Help with Steering Head Bearing Adjustment twistr Troubleshooting for Road Glides 15 07-23-2013 09:32 AM
Help with Steering Head adjustment kbrown82 Do-IT-Yourself 5 03-04-2012 02:40 PM
